Become a member to follow this project and don't miss any updates
SatNOGS - Global Network of Ground Stations
SatNOGS is an open source ground station and network, optimized for modularity, built using affordable tools and resources.
22 336 225
Share on twitter   Share on Facebook
This project was created on 06/04/2014 and last updated 3 days ago.
Description
SatNOGS project is a complete platform of an Open Source Networked Ground Station. The scope of the project is to create a full stack of open technologies based on open standards , and the construction of a full ground station as a showcase of the stack.
SatNOGS provides the basis for:
Bulk manufacturing and deployment of affordable Satellite Ground Stations
Modular design for integration with existing and future technologies
A platform for a variety of instrumentation around Satellite Ground Station operations
A firm platform for a Ground Station collaborative network (one to one, one to many, many to many)
A community based approach on Ground Station development
A solution for massive automation of operator-less Ground Stations based on open standards
Check out our documentation on the website for detailed info.
Details
SatNOGS is a modular and scalable stack for Satellite Ground Station implementation. Fully based on open source technologies and open standards, it provides interoperability with existing or future subsystems.
A Global Management Network is the key part of our stack, connecting multiple observers with multiple ground stations enabling tracking and monitoring of satellites from multiple locations around the world. The data gathered will be publicly accessible through the network website.
SatNOGS project is implementing the above general stack design using 4 different sub-projects.
SatNOGS Network - Our observations, scheduling and discovery server
SatNOGS DB - Our crowd-sourced suggestions transponder info website
SatNOGS Client - An embedded system that receives the scheduled operation from Network, records an observation and sends it back
SatNOGS Ground Station - The actual ground station instrumentation with tracker, antennas, LNAs and connected to Client.
The following System Design visualization depicts all subsystems of a reference implementation of a SatNOGS Ground Station.
A rendering of the finalized ground station (with front cover open) can be seen here:
Components
  • 2 × Stepper Motor NEMA 14 or NEMA 17
  • 2 × 3D printed Gear Assembly Check our repo for designs
  • 1 × Arduino Micro For Alt/Az commands translation and commanding the stepper drivers
  • 1 × TP-Link wr703n For WiFi connectivity and routing
  • 2 × Signal Receiver DVB-T receiver based on RTL2832U
  • 2 × Yagi antenna For 2m and 70cm bands. Check repo for designs
  • 2 × A4988 Stepper Driver Pololu compatible
  • 1 × Odroid U3 For management interface, jobs queue, decoding and receiving
Project logs
  • SatNOGS going Helix
    3 days ago • 0 comments
    An important part of the instrumentation of our ground station is the Antennas. Early on the SatNOGS team designed and constructed 2 Yagis for UHF and VHF bands. The UHF Yagi design was essentially a cross Yagi design trying to address the circular polarization issue. Based on the experimental operation of the ground station we were sure we can do something better.
    Satellites are tumbling and turning, thus if the transmission of the transponder is done in a single dimension polarization you better match this polarity to get the optimum gain. (if not you will loose 30dB) (check here for details). We decided that a Helical antenna would give SatNOGS a better chance for an optimal reception, so we needed to design, document and build one.
    There are a couple of theoretical models for Axial-mode Helical Antennas. Most notable are the Emerson one and the Kraus. We decided to go for Emerson, given our wavelengths, construction constrains and overall size. As we were going for UHF band 437Mhz seemed like a popular frequency for satellite communications and we centered around it. As for the circular polarization we designed a Left-Hand one (as we already had a Right-hand cross-Yagi design).
    Dimitris worked on a modular and extensible design that can be used on other bands too. 3D printed parts and off the self items is the classical recipe that we followed. The result is a sturdy and easy to construct antenna. Initial tests are showing improvements compared to our cross-yagi UHF which is a win!
    The design can be found here, bill of materials here and a detailed documentation on how to build here.
    Optimization of the antenna is crucial. We invested considerable amount of time towards that and there is always room for improvement in matching, constructions and details [1]. More NEC calculations will follow and we expect more fixes as we go.
    [1] http://users.ece.gatech.edu/~az30/Downloads/HelixAPMagazineSubmission.pdf
  • Axis homing tests
    Using the first version of satNOGS hardware we figured out that some times due to various reasons (software, mechanical or power malfunctions) the rotator might end up in an unknown position.
    At that point, the only way to resolve that situation was to manually reset the rotator to home position (pointing at the north with zero altitude). Therefore, since we wanted the rotator to operate without human supervision, we decided that an automatic homing system was crucial.
    At first thought we tried an IMU, which turned out to be too noisy and affected by the rest of the systems so we ended up with a pair of opto-swithes which are manually set at the first run.
    The mounts and activators of the switches are designed in a way that they remain modular and independent of the rest of the tracking hardware so that they can be fitted in previous or future versions.
    Our intention is to write two homing functions in the arduino code
    The first one, which is already written, is called when the arduino boots for the first time or after power loss. In this function, the rotator scans around the current location until it finds home position. Below you can see a video in action:
    The second one runs after every tracking job or on demand through the serial interface and just moves the tracker to the home position. This way, whenever a new traking job begins the user knows that the job starts from zero position.
    You can check the code in our repo, and the designs for the hardware too.
    It was always our intention to have SatNOGS ground station as unattended as possible in terms of operation. We are now much closer to it!
  • SatNOGS Ground Station v2
    7 days ago • 0 comments
    The time we've all been waiting for, has come. We are proud to release v2 of SatNOGS Ground Station (Tracking Box) with many upgrades and fixes from the previous version. Notably:
    • Redesigned Axis Gear Assemblies. They are now smaller, more robust and reliable based around a much more powerful NEMA 17 Stepper Motor. The two assemblies are now structurally connected, making the whole assembly much more rigid. Also we redesigned the Worm Gear for improved printability on 3D printers.
    • Integrated electronics. We designed and built a new PCB to house all electronics (Arduino, and Stepper Drivers) along with an additional PCB as a PSU for voltage regulation and neater cable management. (see previous log)
    • Reworked stepper driving code, featuring a much cleaner code, acceleration and deceleration in movement, stop functions and early opto-homing support. (see previous log)
    Tripod and On-board computer (TP-Link) stayed the same, with developments on them coming down the road.
    A detailed Bill of Materials is available here.
    We have also compiled a detailed construction guide, with step by step instructions on how to assemble the Ground Station Tracking box for both Mechanical and Electronics components.
    http://satnogs.dozuki.com/c/SatNOGS_Hardware
    All Designs and 3D printable files can be found here and all PCB files for our electronics shields can be found here.
    Development does not stop with v2, and we are already working on the homing/zeroing code that will enable the homing parts we included in v2 to function. Moreover based on more testing we are applying to v2 and feedback from the community, we expect minor fixes to be released soon.
    We can't wait to see v2 out there, built by others, so get started and/or provide feedback!
View all 12 project logs
Build instructions
See all instructions
n0p wrote 23 days ago 1 point
For the new electronics shield, I think it would be a nice addition to break out the unused arduino pins. For future upgrades and prototyping of other features.
Are you sure? [yes] / [no]
Pierros Papadeas wrote 22 days ago 2 points
Hey n0p. Indeed a breakout for the unused arduino pins could be useful in the future. We will make sure to add this on v2. If you want you can take a pass on a v2 too :)
Fotis Georgatos wrote a month ago null point
Hi Pierros et al,
I would like to point out, that if we are to implement a many-to-many configuration, this requires scheduling on at least two levels: A) global (=task submission) B) local (=execution site).
This is for example how the LCG (LHC Computing Grid) system has been implemented, crunching tons of data coming out of CERN, for some years already. Iff a FIFO queue at local (B) level is considered sufficient, then this has already been described how it's done in paper [1]; it is relatively trivial implementation for people experienced with the gLite middleware stack. Truth be told, that solution does not take into account celestial and orbital mechanics natively, at least not in a way that would yield near-optimal scheduling. Optimality here is a far more complex problem, which should rather be solved by the groups of users and resource owners. To do that, the concept of Virtual Organizations that grid systems provide, would become handy.
In short, there can be *some* initial solution, but for optimal utilization let's all honestly expect that this is a problem that will take some man-years of effort and tuning! If you are not sure why this would take time, try to play NetworKing [2] and you will understand ;-)
keep up,
Fotis
[1] Solomos, N. H. and Georgatos, F. (2006), System aspects of the EUDOXOS observatories network. Astronomische Nachrichten, 327: 796–799. doi: 10.1002/asna.200610673
[2] http://www.nasa.gov/multimedia/3d_resources/scan.html
Jasmine wrote 2 months ago null point
Hello Pierros & SatNOGS team, I hope you received your Astronaut or Not t-shirts!
Just looking at your project and wanted to remind you that by August 20th you must have the following documentation on Hackaday Projects to be considered for the next round:
- A video less than 2 minutes long describing your project.
- At least 4 Project Logs (you need at least 3 more)
- A system design document (give us a visual overview of how it all works. Highlight the design doc in the details section)
- Links to code repositories, and remember to mention any licenses or permissions needed for your project. For example, if you are using software libraries you need to document that information.
You should also try to highlight how your project is 'Connected' and 'Open' in the details and video.
Good luck!
Pierros Papadeas wrote a month ago null point
Hey Jasmine,
The Video is linked (actually we made a second one too) and we will be publishing the rest of the logs by 20th of Aug. Also links to code repos are on the side.
Does the uploaded Design Document viz meet the requirements?
Marios Papachristou wrote 2 months ago null point
A great project from ardent developers!
Fotis Georgatos wrote 2 months ago -1 point
Hello folks,
The idea of using 100s of SatNOGS together for tracking "whatever" has been buzzing in my mind, after the recent "astroexormisi" event in Mt. Elikonas, Greece, of last week!
There are a zillion of approaches to take about how to run such a setup and I'm growingly convinced that the best way may be to allow a bouquet of technologies to co-exist together.
I started looking at SPIKE and found out it's already 25 years old technology and many more things have sprung up in the meantime, see [1] [2] [3]. Windows of Opportunity (WoP) are an objective to highlight and calculating celestial and orbital mechanics may be the holy grail of this business. Subgroups of SatNOGs may be homogeneous or heterogenous, which affects scheduling dearly [4]. Finally, efforts to integrate observations with data reductions and network transfers should be overlooked and may become relevant [5].
Let me explain:
* This is by far and large a Multi-Objective-Optimization problem
* There are multiple scheduling platforms (SPIKE, ASPEN, Raptor/TALON)
* There are plenty of planning languages that could be of interest (ANML, PDDL, NDDL, AML)
* It is not clear if a push or pull scheduling (ref. "Condor") mechanism is optimal in efficiency
So, neither would ever any single approach be optimal for everybody at the same time!
In short, let's keep the current open API (congrats for that) and, build upon it multiple implementations, perhaps even allowing different coordinated groups to tackle this!
Thanks for reading the long email, F.
Ref.
[1] http://scholar.google.gr/scholar?q=SPIKE+Intelligent+Scheduling
[2] The Deep Space Network Scheduling Problem
http://www.aaai.org/Papers/AAAI/2005/IAAI05-009.pdf
[3] http://aspen.jpl.nasa.gov/
[4] http://scholar.google.gr/scholar?q=htn+telescope+scheduling
[5] https://www.google.gr/search?q=System+aspects+of+the+EUDOXOS+observatories+network
Glenn Powers wrote 2 months ago null point
Since "Connectivity is a key aspect of our project," have you considered using BitTorrent Sync to share the data collected by the network? I'm using it to distribute my DokuWiki:
http://net127.com/
BitTorrent Sync and DokuWiki work well together, since DokuWiki uses plain text files and media files.
BitTorrent Sync is also excellent for synchronizing sites with intermittent network access.
http://www.bittorrent.com/sync
Dan Royer wrote 2 months ago null point
I've been designing 3d printable slew bearings. Would they help?
http://www.thingiverse.com/thing:321679
I use them in my project: http://hackaday.io/project/945-6DOF-Robot-Arm
Manthos Papamathaiou wrote 2 months ago null point
Very interesting piece of hardware Dan. We will definitely think about to use them. Nice robot arm to!
Fotis Georgatos wrote 2 months ago null point
Geia hara Dan, (=hello)
I'm an engineer of the non-mechanical flavor, yet I'm inclined to infer that using such bearings would allow to increase the load envelope that the design can sustain, without pumping the costs too high. If so, that's very interesting. In fact, it might permit to add on SatNOGS heavier loads such as cameras, parabolic antennas and... well, maybe just maybe, small scale telescopes (to be sure: weight-balanced).
and an extra crazy thought: a mechanical robot arm such as yours, placed near the cargo area, could even service some of the equipment (switch receivers & lenses, monitor devices with a webcam, provide load support under heavy weather etc).
Gary wrote 2 months ago null point
would like to see more. Really interested in how well those 3d gear will work with that larger array.
Manthos Papamathaiou wrote 2 months ago 1 point
we will come up with more photos and videos very soon Gary. We are making some changes to the design to make it more compact and more easy to maintain. I think that the v0.2 will be ready very soon.
hpux735 wrote 4 months ago null point
What are you using for the mechanics of the Az/El mount? Are those custom-machined or off-the-shelf?
Manthos Papamathaiou wrote 4 months ago null point
Hello! We are actually using only 3D printed parts and some nuts and bolts.
Adam Fabio wrote 4 months ago 1 point
Pierros, SatNOGS looks great! Thanks for sending it in to The Hackaday Prize. Can you upload a few more pictures of the prototype? Cad drawings are great, but nothing beats seeing those stepper worm drives in real life. I'd like to see more on the connected protocols as well - Can we use SatNOGS to create an open source Deep Space Network similar to the one NASA has?
Pierros Papadeas wrote 4 months ago null point
Connectivity is a key aspect of our project. Indeed the concept is to create a global distributed network for satellite tracking and communications (similar to DSN, but for LEO MEO orbits :) )
Totally, YES!
I am able to tell so, since I saw the prototype in action couple of days ago, and it simply does what you would like it to do. The design is quite open and extendible. An area of possible improvements is to use more expensive materials as a matter of hardening it (eg. for harsh weather) yet its design is sound and, reusable to the max!
btw.
if you are on Apple or Wintel devices, check out this game (set aside 20mins):
http://www.nasa.gov/multimedia/3d_resources/scan.html # read objectives!
It will take you to the i-am-looking-forward-to-DSN mode quickly ;-)
Very useful and edutaining time-killer for long hours in airport/airplanes.
IMHO, it should be declared the official game of SatNOGs followers!
btw.
keep dreaming of possibilties, you never know what may happen with newer ideas!
http://www.technologyreview.com/article/403435/space-tracker/
Mike Szczys wrote 4 months ago null point
Thanks for submitting this as an entry for The Hackaday Prize. You should add "TheHackadayPrize" as a tag.
As you get further along with your documentation make sure to look over the requirements and judging preferences. For instance, more documentation on your communications protocol would help satisfy the "connected" requirement and improve on the "open" preference.
Pierros Papadeas wrote 4 months ago 2 points
Thanks for the suggestions Mike! We will make sure to publish the documentation with the requirements and judging preferences in mind.
