Electrical tape is a valid construction material...
A project log for £100 Google Glass using Raspberry Pi
DIY Google glass but done properly
danielmcgrawdanielmcgraw 08/20/2014 at 22:230 Comments
Now we had the electronic components working, it was time to test it out. For this, I only used the electronic components without worrying about the optics. This meant I temporarily mounted the LCDs outside the glasses just to check that they worked.
This works with the two units separated across each end of the room with now degrading of the image. The glasses were still very light and comfortable, despite the fact they were covered in insulation tape. This has appeared promising so we will now combine this with the optics to make the Mk2 MUCH more aesthectically pleasing.
