NMR/PPM Concepts - Part 1
A project log for PyPPM: A Proton Precession Magnetometer for all!
A device for conducting Nuclear Magnetic Resonance experiments at Earth's field
bradley-worleyBradley Worley 09/08/2014 at 03:242 Comments
Hey everybody! I finally got around to making the first video on what will probably be a three-part set on the fundamentals of NMR, PPM's and PyPPM.
I tried to keep it as simple as possible, without clouding the waters with too many equations. Please let me know if you have any questions, comments or requests!
Also, I'll post a short demonstration video of PyPPMv1 tomorrow, so stay tuned!
~ Brad.
Elia wrote 09/13/2014 at 14:22 point
Well there seem to be no comments here but at least I think that this is an interesting and easy to understand explanation of the concept used to acquire the decay signal.
So I assume you can identify different elements in the sample by examining the spectrum of the resulting decay and looking for specific decay/rotation frequencies? Does this work only with elements or would molecules react in the same way?
Bradley Worley wrote 09/16/2014 at 17:00 point
Hey thrash, good question! In NMR, the nuclei we manipulate are almost always bound into molecules.
Many elements have isotopes that are 'NMR active' (13C, 15N, 31P, 19F, even 2H) that we can measure, and yes, they show up at different frequencies. A super cool experiment to do on PPM's is to acquire a decay from something with both 1H and 19F: because their frequencies are so close together, you get a trippy, easily identifiable beat pattern in the time-domain signal.
