Pulse programs are here!
A project log for PyPPM: A Proton Precession Magnetometer for all!
A device for conducting Nuclear Magnetic Resonance experiments at Earth's field
bradley-worleyBradley Worley 09/24/2014 at 21:300 Comments
Hey everybody! I'm back from a 96-hour coding binge with some amazing new PyPPM features to give you, in the form of pulse program support.
Pulse programs are the software glue that brings all the new features promised in the PyPPM 2.1 hardware together in a powerful way. I've also back-ported them to older hardware/firmware versions, so you can write one pulse program on the v1r3 hardware, and then immediately run it on the v2 hardware if you choose to build it. Cool, huh?
Finally, because pulse programs are tricky little beasties, I'm starting to compile a library of known-to-work programs that can be used with PyPPM.
Let me know what you think!
~ Brad.
