Become a member to follow this project and don't miss any updates
Open Source Science Tricorder
Science in your hand. A pocket-sized instrument capable of visualizing and exploring the world around you.
26 241 226
Share on twitter   Share on Facebook
This project was created on 06/07/2014 and last updated 4 days ago.
Description
It is my deep belief that knowledge brings about positive change.
We could live in a world where the same instrument that can show a child how much chlorophyll is in a leaf could also show how them much pollution is in the air around us, or given off by one's car. As an educator and a researcher, I feel that if people could easily discover things about their worlds that were also important social topics, that they would then make positive social choices, like reducing their emissions, or petitioning for cleaner industry in their communities.
By having access to general inexpensive sensing tools, people can learn about healthy leaves, clean air, clouds and the water cycle, energy efficient homes — and visualize abstract concepts like spectra or magnetism.
As a tool for exploration, we can discover things around us that we don't already know. And that's what it's about. Little discoveries, everywhere.
Details
Concept Video
Hardware and System Design
The Arducorder Mini is an Arduino-compatible handheld sensing device, and the next iteration of my open source science tricorder-like device project that's designed to be easy to use, have a large array of sensors, and easy to share sensing discoveries.  The Arducorder Mini is designed to foster a community of open source users and development, and is ChipKit MAX32 compatible, which is a port of the Arduino platform to the much more powerful PIC32 family, and makes use of a PIC32MX795F512L with 128k of RAM, 512k of flash, a zippy 80Mhz processing speed, and a fantastic set of peripherals for interfacing to sensors.
The current prototype is designed to use a 1.5" OLED with 128x128 pixels and 16-bit colour, a touch interface, and connectors for 5 modular sensor boards that each contain several sensors.  The sensor boards are designed to be interchangeable and upgradable, so that a large number of configurations are possible with different sensing capabilities and price points.
While the Arducorder Mini is being designed with a wide array of sensing capabilities off-the-shelf, it's also designed to be easy for folks to tinker with and upgrade. Accessibility is a central goal of the project -- If you're familiar with Eagle CAD and have ever made an Arduino shield, it should be easy to design your own sensor board. Using OSHPark and Digikey, the parts cost for a new sensor board (PCB and header, not including sensors) is about $5, which is even less than most protoboards!
Sensing Capabilities
The current prototype has been designed to include the following sensing capabilities:
Atmospheric Sensors
  • Ambient Temperature and Humidity: Measurement Specialties HTU21D
  • Ambient Pressure: Bosch Sensortec BMP180
  • Multi-gas sensor: SGX-Sensortech MICS-6814
Electromagnetic Sensors
  • 3-Axis Magnetometer: Honeywell HMC5883L
  • Lightning sensor: AMS AS3935
  • X-ray and Gamma Ray Detector: Radiation Watch Type 5
  • Low-resolution thermal camera: Melexis MLX90620 16×4
  • Home-built linear polarimeter: 2x TAOS TSL2561
  • Colorimeter: TAOS TCS3472
  • UV: Silicon Labs Si1145
  • Open Mini Visible Spectrometer v1 using TAOS TSL1401CL 128-pixel detector, with NeoPixel light source
Spatial Sensors
  • Inertial Measurement Unit: Invensense MPU-9150 9-axis (3-axis accelerometer, gyro, and magnetometer)
Other Sensors
  • Microphone: Analog Devices ADMP401
Check out the project logs for the current build progress, and stay tuned!
GitHub Repository and Source Files
The source files are available on the Arducorder Mini GitHub Repository as the development progresses.  The hardware is licensed under Creative Commons By-Attribution Share-Alike 4.0 International, and the firmware and libraries are available under various open licenses.  Please see the licenses file included with the source for more information.
Project Log Navigation
The project logs help tell the story of the project's development, from concept through assembly and revisions:
1: An Introduction and Background
2: Concept and Industrial Design
3: Board Layout Part 1
4: Board Layout Part 2: Motherboard
5: Board Layout Part 3: Lots of boards!
6: Beginning Motherboard Prototype Assembly
7: Assembling the First Sensor Boards
8: Sensor Board Mega-update
9: Capacitive Touch Wheel
10: Wifi Module Update
11: Spectrometer Board Design, and Beginning User Interface
12: Tile-based User Interface, and Spectrometer Board
Project logs
  • Tile-based User Interface, and Spectrometer Board!
    5 days ago • 0 comments
    User Interface Design
    Visualization and user interface design is a hobby that I really enjoy, and I've been lucky enough to have friends and colleagues who are usability and visualization folks that I've been able to periodically soak information up from.  The open source science tricorders present a really interesting UI problem -- where most mobile devices have at most a few different sensing modalities, here we have 12 different physical sensors, each of which measures between 1 and 3 different things!  What's more, while some of these measurements are single values (like temperature, say 24C), others are vector values (like the three separate 3-axis vectors coming from the MPU9150 -- one vector for acceleration, rotation, and magnetic field strength, giving nine values total, from a single sensor).  In the extreme case, the spectrometer returns a vector of 256 values. That's a lot of data!  I'm really not aware of any other device that comes close to having so many different kinds of sensing data pouring into it constantly, and while this is very exciting, it's also challenging -- we want folks to intuitively browse and navigate through that data very quickly.
    I've spent the past few weeks researching design concepts for user interfaces by browsing popular design websites, and talking to some friends, and I think I've settled on a very intuitive, attractive, and useful interface design.  I'll confess that I've been working harder, not smarter about this in recent years -- I'd try and design very complicated things that looked like how other people had done mobile devices and visualization (like android phones), which is a fantastic amount of work for a single human being.  Starting this Arducorder mini project almost 4 months ago, and keeping it attractive and capable but tractable has finally helped me work smarter about this, and figure out a lightweight, usable and intuitive interface concept.
    I like the idea of live tiles.  When done well, it reminds me of Danny Hillis's idea (30 years ago) about maximizing the amount of computing silicon active on a processor at any one time, but attractively applied to data visualization.  Instead of having icons that just take up space and give you a name, here you have tiles that display a live updating value.  This is powerful from a usability perspective -- instead of having to enter each application to obtain this information (which can consume a lot of time), the most important information is available at a glance from many applications.  While this has largely been applied to communication (e.g. messaging), web (weather/news), and I'm sure sensing applications, here we're going to construct an interface  made almost entirely of sensor data.
    The really interesting aspect (if you're a data abstraction nerd, like me) is that if we consider only this special case -- visualizing sensor data through tiles -- then we can formulate the software engineering aspect of this very elegantly.  If each tile has a sensor data buffer behind it, then we can browse it's most recent data on the top of the tile, then activate the tile to display additional (historical) data and different visualizations.  If we abstract the sensor data buffer into a few different types, like continuous streaming data (from something like a temperature sensor or an accelerometer) and discretely sampled data (from something like a lightning sensor, that only activates when an event occurs), then we can get rid of the idea of an application.  The design concept becomes browsing sensor data buffers first through a high-level tile interface, and then activating an individual buffer and using a suite of generic visualization tools to better explore it.
    Interface Implementation
    All of the software engineering aside, what the user sees is very attractive -- tiles with live data that they can browse through very quickly with...
  • Spectrometer Board Design, and Beginning User Interface
    18 days ago • 0 comments
    A quick update with lots of progress designing the spectrometer (and thermal camera) board, attaching the radiation sensor board, and beginning to work on the low-level routines for the user interface!
    Fast and Efficient Bitmap Rendering
    Now that much of the hardware is in good shape (or being fabbed), I've been working on the low-level software and APIs that would support building an intuitive and attractive user interface.
    A bit of background -- from my hobby of indie game development in undergrad and participating in the Ludum Dare 48-hour game competitions (a really fun experience!), I've picked up that in a desktop system (and some embedded systems), a graphical user interface is often functionally implemented as a large collection of bitmaps stacked atop each other with transparent layers.  This has the benefit of being able to make large changes to the user interface through editing configuration files that describe which bitmap corresponds to which background or widget or font (instead of recompiling code), and also allows the user interface artist to easily use whatever tools they're most comfortable illustrating in to rapidly iterate without having to use middleware, or (even worse) be constrained to building an interface entirely out of low-level graphics primitives like squares, ellipses, and triangles.
    This is the approach that I'd initially planned on using, but I'd discovered about a month ago when running a display verification test that the ChipKit SD card library has a read speed of around 100k/sec, which puts the time to load and display a bitmap on the order of about one second -- far too slow for an interface.  There are faster libraries like sdfat, but these required more than a solid evening of porting, and at some point you have to put these on the wishlist, accept the constraints, and exploit the benefits of your existing system while architecting it in such a way that you could drop more advanced functionality in later with a minimum of effort.
    Posterizer Tool
    While loading bitmaps from an SD card is currently slow, the PIC32MX processor that the Chipkit Max32 uses does have 512k of flash memory that (in addition to code) can store bitmaps that can be loaded very quickly.  A full screen (128x128) 16-bit (2bpp) bitmap takes 32k of memory, so we can't fit very many in memory, but if we manage our resources and store things efficiently, we should have plenty of space for backgrounds and widgets and icons in ~128k or so.
    One way of compressing bitmaps is to reduce the colour depth -- if we can reduce an image from 16-bit colour (64k colours) to 8-bit (256 colours) or 4-bit colour (16 colours), then we can store the image in half to a quarter of the space.  The trick is selecting a smaller colour palette so that the final "posterized" image still looks very good.
    There are automated algorithms to do this, but they often give non-ideal results, and I want this thing to look /good/.  I've been looking at user interface concept art the last few days to get ideas, and I'd had the idea of having a main menu that showcases a space theme by having a scrolling background under an icon-based main menu with multiple pages of icons, similar to Android.  I grabbed a copy of NASA's amazing public "earth at night" photograph, downsampled it to 256x128, and used manual posterizing tool I quickly put together in Processing to reduce the colour depth to 4-bit, and store the image as a static array in flash.  Despite being 256x128, the image only uses 16k of flash, and the manual conversion (above) is so good compared to an automated algorithm that I would never have known it was poserized if I didn't do it myself!  It also scrolls back and forth at about 50fps, which looks really impressive.  While I'm still deciding the final user interface concept, it was a good test, and a useful tool to compress the graphic assets into flash so that they're...
  • Update: Now with 100% more WiFi!
    a month ago • 1 comment
    A quick update, with some of the high-risk high-gain aspects of the project!
    CC3000 WiFi Module and ChipKit Library Port
    It's great to get out of your comfort zone and learn new skills or expand your familiarity with different aspects of design.  For me, in addition to the capacitive touch wheel, I decided to include the popular CC3000 WiFi module from Texas Instruments.  I think connectivity fits a lot of the use cases for a science tricorder-like device, from kids using social media to share their sensing and measurements to engage themselves and their friends, to nerdy scientists that spend their entire days in the lab (like me) who would like to push all their raw data to somewhere like data.sparkfun.com for sharing, advanced visualization, or later analysis.  Personally, a neat visualization experiment I'd like to try is to sit the Arducorder Mini on my desk for an afternoon when we're expecting a storm, and visualize the storm coming in through data -- the decreasing temperature and pressure, increasing humidity, reducing distance-to-lighting, and it'd be neat to see if any x-rays from close lightning strikes are detectable and coincide with the lightning detection.
    This is my first use of a WiFi module in a project, and so my concerns in terms of hardware were routing the antenna traces correctly, and being able to successfully interface with the module using an open library.  There are a number of open reference designs for the CC3000 antenna circuit, and space being at a premium I ended up using the same layout as the folks who designed the open Spark Core (thanks Spark team!).  In terms of open ilbraries, Adafruit released their CC3000 Library, which was recently ported to the Due, which would give me a trail of github commits to look through when porting to the ChipKit MAX32-based system that the Arducorder Mini is based upon.  It all looked good, so I incorporated the CC3000 module into the Arducorder Mini motherboard.
    To make a bit of a long story short, I ran into a problem similar to the issue with the capacitive touch sensor requiring the ChipKit I2C library to be updated from the Arduino 0023 libraries to the new Arduino 1.x (post-Due) libraries, to make use of the additional features that have been added in the last few years.  With the capacitive touch sensor, it was fairly easy to add the repeated stop condition support from the newer Arduino 1.x I2C/Two-Wire libraries, but the Adafruit CC3000 library is based on the much larger Arduino 1.x ethernet library, so there was a good deal of effort involved -- porting the Adafruit CC3000 library from the AVR/Due to the PIC32 from the top, while simultaneously updating the ChipKit Arduino peripheral libraries from the bottom.
    Fully updating the ChipKit libraries to Arduino 1.x would be a full-time task for someone familiar with their inner workings for a good week or two, so it's well beyond the scope of this project -- but after a solid weekend of work I was able to successfully port enough of the Arduino 1.x ethernet library (and its dependencies) to then port the Adafruit CC3000 library to the ChipKit!  The picture above shows success, and the Arducorder Mini successfully fetching its first webpage and displaying it over the serial console.  Great stuff!
    In the end, this means that in order to compile the Arducorer Mini firmware, I'll also have to maintain an updated version of the MPIDE on the github repository.  A side effect of this will be that Chipkit folks should be able to enjoy the benefit of some (partial) Arduino 1.x compatibility.
    Open Mini Spectrometer
    In addition to the WiFi module, the other high-risk high-gain aspect of the Arducorder Mini is creating a new version of the open mini spectrometer suitable for one of the low-profile modular sensor boards.  I really needed to build (and not code) last weekend, and have been boring...
View all 12 project logs
Andrej Mosat wrote 12 hours ago null point
Hi Peter, excellent project.
I was reading your questions on mini spectrometer page. One of them was: how to better connect the grating to the enclosure. I use double-sided automotive 3M foam tape, which just works. Maybe you already use the same system, but I could not find how you actually do it. You would also like to use 4mm optics, I might have some suggestions, but again, could not find exactly what the design requires, like the focal length. What is your workflow in programming / debugging / engineering the PIC32 ? It seems like Chipkit Max32 with the modified Arduino / PIC32 platform. Have you found a better diffraction grating? I have an answer to manufacturing of precise, cheap optical slits. What would be the quickest & plug-n-play way to obtain and test your mini spectrometer? Thank you!
Are you sure? [yes] / [no]
Steve Pomeroy (xxv) wrote 8 days ago null point
Sweet project. Have you considered using a pre-made GUI/OS layer? You could build on top of things like Linux, QT, Android, etc. and save a ton of dev time.
I suspect one of the things that really make a project like this shine are the way the data are interpreted and visualized, which would be pretty hard to do with an entirely hand-rolled GUI layer. Cheers!
peter jansen wrote 6 days ago null point
Thanks Steve. Microcontrollers are very different than desktops, and have much more modest computational resources, so they're not usually able to run OS's, and the few that they can run are a little complicated to code for. The PIC32MX I'm using has the most RAM of almost any commodity microcontroller (128k), which is barely enough for a display backbuffer and some rolling buffers for the sensor data. :)
Developing an attractive and intuitive GUI from nothing but a pointer to video memory is a bit of work, but it's also a lot of fun, and very rewarding. Architecting it well in this case also means that folks will be able to customize it with very little background knowledge, and (more generally) that Arduino/ChipKit folks will have a lightweight GUI library that they can use for completely different projects.
Over the past few weeks I've been browsing through a lot of design concepts for ideas, and designed something like a Live Tile interface that's controlled through the scroll wheel. It's very intuitive, and looks beautiful, and feels very good on the actual device. There's still a bit of work to do (and the deadline is coming up), but I'll post pictures shortly! Stay tuned!
justin.m.riddle wrote a month ago null point
This looks freaking incredible. When the first round is ready for purchase I'll be first in line. My dad is a superintendent of a golf course, and could use something like this to detect soil and water chemistry, weather conditions, and we could even build a sensor that interfaces with his irrigation system. So many possibilities! Good work, I'm very impressed. I'm guessing this is going to get you to space.
peter jansen wrote 20 days ago null point
Thanks for your kind note. I hope you and your dad will get to have all sorts of fun with one, I'd love to see how it works out for that environmental monitoring task!
Jasmine wrote a month ago null point
Hello Peter,
there are a few small things you can do to your documentation give your project the best chance of going through to the next round of The Hackaday Prize.
By August 20th you must have the following:
- A video less than 2 minutes long describing your project. I see you have a couple of videos. Put a link to the one you want our judges to watch most in the external links section.
- At least 4 Project Logs. You have this covered.
- A system design document. Is it this image https://static.hackaday.io/images/5974661405800489211.jpg?
- Links to code repositories, and remember to mention any licenses or permissions needed for your project. For example, if you are using software libraries you need to document that information. You can highlight these in the project details or external links section.
Thanks for entering. Good luck.
Jasmine
peter jansen wrote a month ago null point
Thanks Jasmine, I think I've put everything up today, including the updated video, the system design diagram, and uploaded the current source snapshotto the GitHub repository!
James wrote a month ago null point
maybe in a future version you could add a full-color lcd, and an infrared camera for monitoring heat, and plant chlorophyl levels.
Hi James, the OLED is a beautiful full 16-bit colour (the graphical user interface is just unfinished), there will be a low-resolution thermal camera, and the spectrometer may be able to monitor chlorophyl levels. :)
[deleted]
peter jansen wrote 2 months ago 0 points
I mean, you're not wrong -- if you don't value science based on observation and measurement, science education, or being generally interested in learning more about the world around you, then yes, this device will be of little use to you.
If you've taken high school chemistry or physics, you should know about measurement error, and that every measurement from every device has some accuracy and repeatability associated with it -- for example, 25C +/- 0.1C. This is a fundamental property of all sensors (electrical engineering), or the nature of measurement (physics), and is true of a one dollar sensor or a million-dollar instrument. That being said, nearly all of the sensors have been chosen to be particularly accurate, especially for their price point. I think there was an example floating around where the atmospheric pressure sensors are so accurate that, under ideal conditions, you could nearly measure someones height just by measuring the atmospheric pressure at their feet and head, and subtracting the two altitudes you infer from those pressures.
As to why I might be a trustworthy source on sensing and science education, Yes -- I do have a PhD, and have spent the last decade choosing to do academic research (for much less than one makes in industry), teaching, and donating my evenings to projects that help make it easier for folks to learn science -- because I love it, and think it does a world of good. But, as always, you should critically evaluate any source (including me) before you trust what they say.
All that being said, if (after taking time to sleep on it), you still don't understand why folks might find this project exciting, that's okay too. But now that you've (repeatedly) voiced your very strong opinion, I think there are lots of more productive things we can all do with our time.
Best wishes.
[deleted]
I'm not sure what you mean -- the open source science tricorders I've been building for 7 years are clearly very real devices. In the case of this one, the Arducorder Mini, when complete it will have about a dozen different sensing modalities. It's basically a multitool for science, like a swiss army knife. So maybe your question becomes, where would you use a thermal camera? Where would you want to detect radiation? Where would you want to characterize the atmospheric conditions of an environment, or sense potentially harmful gasses? Where would you want to take the spectra of an object? And so on...
Piotr S wrote 2 months ago null point
I fully support your Project.
Few things from my Point of View:
The Case Design should be more Handheld like an Remote
And when it comes to remotes. What about an IR Transmitter/Receiver Package?
peter jansen wrote 2 months ago 1 point
Hi Piotr, the industrial design shows that the Arducorder Mini is handheld, like a phone or MP3 player?
Could you make a scientific use case for an IR transmitter/receiver? And what wavelength?
I was considering that IR waves are everywhere.
And you could use it to read signals from Remotes and other IR driven Devices.
With the Transmitter you could even copy those Signals.
Greetings and thanks for the Questions :)
Fredwordsplat wrote 2 months ago null point
I Recommend A Voltage Detector With a Detachable Housing and Wireless InfraRed Communications. Like Doctor Bashir uses to Scan Humanoid lifeforms For Injurys.
Image of Scanner :
http://2.bp.blogspot.com/-NP06Lgv6zyA/UFAflMA_WhI/AAAAAAAADBk/LMVzn_71k3c/s1600/Improved+Star+Trek+Medical+Tricorder+Papercraft.jpg
I Love The Thought of a Tricorder. I am both a programmer and a Trekker (Star Trek Super Fan!!). I Support This To The Max!!! Epic :)
matt venn wrote 2 months ago null point
super inspiring!
Gasump wrote 2 months ago null point
I agree with jixijenga; a modular sensor system would be a good idea, that way people can adapt the tricorder to their personal needs. For example - people living near a manufacturing plant that 'smells bad'. They could test for various gases/chemicals that could be harmful to their health. While I don't fear opening up and swapping components, I also think the plug in 'accessory' sensor block is a good idea. There is not much commonality in gas/chemical sensors formats so it would be more difficult to accommodate a wider range of possibilities in the instrument dimensions you are working - which I think is spot on!
But there are new electrochemical sensors (much better for specificity than MOS) available that are about the size of a thumbnail and only 4-5mm thick.
You are doing excellent work, keep it up!
peter jansen wrote 2 months ago null point
Thanks Gasump! If you have a look at the project description, video, or the project logs, you'll see that the design is ultra modular with 5 modular sensor boards, 4 of which share a common footprint so that they can be interchanged in position. It should also be relatively easy for someone who's designed an arduino shield to put together their own sensor boards. All of the sensor boards are on the outward surfaces of the device, so if you're willing to make your own case mods, it should be possible to accomodate larger sensors of different dimensions (like those giant gas sensors you mention).
One of the current sensor boards (the atmospheric board) contains sensors for atmospheric temperature, pressure, humidity, as well as three gasses using a tiny sensor similar to the ones you mention -- have a look in the project log Step 2: Concept and Industrial Design for more information.
thanks!
Boz wrote 2 months ago null point
Very similar, yet totally different to my project, I've upvoted it just for the awesomeness of what you're trying to achieve.
Noman wrote 3 months ago null point
Anxiously waiting for the updates and checking project daily I found boards log. Breakout boards for sensors and compatibility of interfacing is cool. Another expansion option might be possible through a converter board that would enable any standard (if there are any standards for these) breakout sensor board from sparkfun or adafruit to plugin to device, or this may be expansion slot?
Capacitative touch wheel is another innovation added and it is impressive. You are not adding ultrasonic sensor due to size limitations but how about adding HB100 doppler motion sensor? Also will the mic would be able to listen to bats?
Sorry for too many questions but that's what strike my mind while reading through.
peter jansen wrote 3 months ago null point
Hi Norman,
I'm hoping that after the device is completed, that instead of working on building these open source science tricorders, there can be more focus on building new sensing packages for them. I'd love a small distance sensor, but I'm not sure that there are any good options out there yet. The HB100 is interesting, but I think also much too large (I think it's nearly half the size of the Arducorder mini!). It also seems to only measure relative change in motion (like an accelerometer), rather than position.
There really are no standard pinouts for sensor boards from sparkfun or adafruit. But with such a low cost to spin your own sensor board, the barrier to creating your own sensor module is much smaller.
Jixijenga wrote 3 months ago null point
Noman, Dr. Jansen,
Perhaps later iterations of the tricorder could have a modular sensor system? Like a plug and play type setup, you pop open the housing, unplug the board(s) and then plug in a different one. We've reached an understanding with technology now that upgrading one's computer isn't seen as a daunting and highly technical challenge anymore, it's largely switching out or adding components that conform to a standardized plug or socket. I think that any advancement in this tricorder could benefit greatly from having such a system, rather than defining the capabilities based on packages or defined variants. An end-user, no matter how uninformed they may be, could customize and configure their tricorder for use in their life. Perhaps people sharing a tricorder could have entirely different uses, and require constant switching of sensors.
Or maybe have a USB type getup, where the sensor packages or modules aren't just restricted to a tricorder and can be used in anything that accepts a USB device. I think that would be great, because while a handheld tricorder is cool, (very cool actually) giving basically anyone with a laptop the ability to emulate one would be even better. Especially for people who wouldn't be able to afford the purchase, or construction, of an entirely new device but would benefit from it's functionality. Perhaps the tricorder could have little "ports" where you plug in this small card-like sensor with a USB plug on the end. I'm sure such a modular and truly plug-and-play sensor would be very robust and durable, further enhancing the utility of the tricorder.
Dear Dr. Jansen, thanks for your kind and informative reply. Yes, BLE and IOS device attachment both have their drawbacks. TechBasic (Basic programming language) skips any need to know IOS programming, I found it easier to use than my aged Casio 880P. I suggested BBB as it is fully opensource and has a small footprint but larger as compared to your mini tricorder version, off-course. I can not wait to see Mini version come to life. I would like to contribute in kind for any component or anything holding it back to come to reality.
Hi Norman,
Thanks for your kind note, and those are good questions. There are a few main thing that limit making this into an open source sensing device that connects with your phone (I've thought about this a bunch of times, as a potentially simpler route to development). One of the main issues is the BLE bandwidth is very limited, only around 1k/second -- way too slow for some of the sensor data. There are also mechanical issues trying to make one device that could mount to different phones (and not obscure the camera), software issues (I'm not an iOS or android programmer), and cost issues (ideally I'd like to make these available for kids, and it'd be unfortunate if the kids also were required to have a $500 phone to pair the sensors with).
I've investigated using different platforms -- the gumstix, the new raspberry pi compute module, and the beagle bone black, just to name a few. The major issues are size and power draw. With this mini version with a motherboard designed from the bottom up for size, portability, modularity, and power efficiency, I've designed it to be small enough to comfortably fit in pocket, and ideally have a lengthy battery life (more than just the hour or so you're likely to get with any of the modules I listed above).
I am a tricorder enthusiast since childhood. Dr. Jansen, you has come a long way [4 Gen before this 5th Gen device creation! Cool] and doing a great job. Brilliant. To me it is more inspiring and motivating project than any of others.
I am just curious, how about using an "IOS device with TechBasic" as front end while MC+Sensors board connected through BLE doing sensing job? TechBasic is good at graphics and visualization of data. Also how about using BeagleBone Black as main board with LCD Cap?
