Become a member to follow this project and don't miss any updates
Global radiation monitoring network
The uRADMonitor is a plug-and-play, low power, self contained radiation monitoring device, with a network interface used to centralise data.
22 106 142
Share on twitter   Share on Facebook
This project was created on 06/29/2014 and last updated 20 hours ago.
Description
The uRADMonitor is a completely assembled and functional radiation dosimeter unit. In the current models, the radiation detector is a Geiger Muller tube. The electronics provided are self sufficient: there is a fast microcontroller, a precision regulated high voltage supply, a digital counter and a network interface (Ethernet). The detector works by itself, while consuming very little power, measurements show only 0.8Watts of power! It could almost run on a single AA cell for hours, or it could easily be powered by a solar power source.
While the hardware is globally distributed , the second component of the project - the server is a centralised NODE, receiving the data reports. The uRADMonitor sends small packets of data every minute, so we have an excellent resolution to the measurements.
What started as a hobby project with just a simple Geiger Clicker, has now gone digital to global level, and the first units are already running: http://www.uradmonitor.com . Done as DIY.
Details
In the beginning there was the passion for technology. I decided to start a blog and write about the things I’ve built. I was more into high voltage, physics and various experiments, cool, but with little or zero use to those around me. Then I decided it was time to build something useful, to put my time and energy into something that would eventually come to do good. I already had the high voltage inverters and a few Geiger tubes in my toolbox. In just a few minutes my first Geiger counter was clicking indicating radiation detection. It was early 2011.
As a software engineer, I found microcontrollers exciting, and easy to use. I didn’t learn electronics in school, it was something I acquired during my spare time activities. But an effort done with passion overcomes obstacles easier. With my new advances in electronics, I decided to build a radiation monitoring station, with an Ethernet interface to have it function in an automated fashion by pushing data online for anyone to view. Slowly, the idea I was looking for, was shaping into reality.
The station, named uRADMonitor (from micro radiation monitor), quickly caught local press attention. It was featured in online and local publications, and I even had the chance to talk about it on TV.
Pushing things forward I got to learn about PCB design, tiny SMD electronics and hardware bugs (worse than any bugs known to a software developer). It was a long road of finding mistakes and perfecting the design. Some of that is documented in multiple posts on my blog and progress can be tracked there. But finally, in October 2013, precisely one year after my original uRADMonitor station, the first prototype for the new distributed network of radiation detectorswas seeing the daylight and passing the first tests with good results.
This is how uRADMonitor began, in an effort of building a distributed global network of detectors, calibrated to the same reference to offer consistent radiation measurements regardless of location, to function autonomously and use very little power while pushing the data online to the centralised webportal and to be as plug-and-playable as possible requiring the user to only plug in the power cable (5V DC) and the Ethernet cable (for Internet access). All the rest is done automatically: registering to the network for an IP via DHCP, accurately measuring time and radiation pulses and finally sending everything out to the server.
The system design document:
Here is a presentation video
A previous code revision is available as open source on Google code. Use it as an initial reference. The final code will be released when this project reaches a stable state.
Probably this is one of the best examples of Connected technology, combining the software with the hardware like poetry, going from microcontrollers to Geiger tube and high voltage inverters, coding in embedded C up to PHP and SQL. Hardware dosimeters to do the hard work, and webpages or Android phones to show the data, as the radiation measurements will also be available soon, via an Android app on the Google play.  Technology interconnected at its best, to serve a useful purpose and help us all (global) stay safer.
Components
  • 1 × enc28j60 mini module Great for opening the internet to microcontroller projects
  • 1 × atmega328p Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × Geiger Tube SBM-20 or SI-29BG Russian Geiger tubes made for the military - robust and very accurate
  • 1 × Aluminium Enclosure Rugged enclosure to make the detector indestructible.
Project logs
View all 26 project logs
Jasmine wrote 7 days ago null point
Hello radu.motisan, now is the time to add a few more details to your project to give it the best chance of going through to the next round of The Hackaday Prize.
By August 20th you must have the following information on Hackaday Projects:
- A video. It should be less than 2 minutes long describing your project. Put it on YouTube (or Youku), and add a link to it on your project page. This is done by editing your project (edit link is at the top of your project page) and adding it as an "External Link"
- At least 4 Project Logs (you've got this covered)
- A system design document
- Links to code repositories, and remember to mention any licenses or permissions needed for your project. For example, if you are using software libraries you need to document that information.
You should also try to highlight how your project is 'Connected' and 'Open' in the details and video.
There are a couple of tutorial video's with more info here: http://hackaday.com/2014/07/26/4-minutes-to-entry/
Good luck!
Are you sure? [yes] / [no]
radu.motisan wrote 6 days ago null point
Thanks Jasmin, I'll do my best to meet the requirements before the deadline.
Radu
radu.motisan wrote 3 days ago null point
I believe this entry now has everything in place. Thank you for the reminders, both here and on email.
davedarko wrote 7 days ago null point
I'm just here to drop my kudos! Awesome project, pleasing pictures!
Dreistein wrote a month ago null point
Have you thought about powering the whole thing over ethernet? Saves the AC/DC adapter http://en.wikipedia.org/wiki/PoE
radu.motisan wrote 16 days ago null point
yes, that would be a good improvement.
Marius Popescu wrote a month ago null point
Awesome project!
I'm curious, do you happen to know a source for buying these russian-made geiger tubes in larger quantities?
yes, Ukraine :)
Adam Fabio wrote 2 months ago null point
Great project Radu! Thank you for entering The Hackaday Prize! We need a global network to monitor radiation - ASAP! If you haven't already, you should check out freaklabs talk at the 2012 OH summit, and his work with Tokyo hackerspace. Great starts there!
Keep the updates coming in - How do you test those Russian tubes to be sure they're still good?
screen Name wrote 2 months ago null point
Nice. Seems like you evaluated the whole thing. Maybe I am blind, but I did nit find an answer to this: Does your current design include a discriminator for evaluating impulses? If yes, I'm curious how it works. I've once used a commercial devie which magically transfers impulses in some gaussian shaped pulse allowing you to cound and evaluate energy. Regards.
radu.motisan wrote 2 months ago null point
There is a pulse counter and it has a discriminator (part of the digital circuit), but it doesn't extract any information on radiation energy.
This functionality is usually implemented with different detectors such as scintillation probes or proportional counters, not geiger tubes (almost ignoring the radiation energy in their geiger plateau: http://en.wikipedia.org/wiki/Proportional_counter#mediaviewer/File:Detector_regions.gif )
If things go well, we might see an uradmonitor also capable of measuring radiation energy somewhere in the future (perhaps using an array of PIN photodiodes). We could then have a hint on the type of radionuclide involved.
ghzatomic wrote 2 months ago null point
Very nice man ... great project ... i hope to help the world with my projects as well as you
Thank you, let's hope for the best!
paolo wrote 2 months ago null point
you can add more sensors:
pollution sensor
co2 sensor
radon sensor
uv sensor
I did for the first station built, see: http://www.pocketmagic.net/2012/10/uradmonitor-online-remote-radiation-monitoring-station/#charts . But for these distributed detectors, I need to keep a balance between costs and reaching the target. What I presented here is the Model A, there will also be a model B, featuring temperature and barometric pressure sensor (needed to estimate altitude).
Victor Cazacu wrote 2 months ago null point
Awesome work Radu! ;)
Thank you!
Mads Barnkob wrote 2 months ago null point
Great to see this project! Most of the other distributed radiation networks is only concentrated in the US with a few measurements from Europe.
I am really looking forward to a greater number of monitors spread around the globe and the possibilities to visualize the data with the google maps API.
Keep up the good work!
Thanks Mads!
bremenpl wrote 2 months ago null point
Hey there, great project :). One thing i noticed regarding projects containing ethernet connection is that ppl still tend to use the enc28j60 chip with an 8 bit mcu instead of a 32 bit mcu with ethernet pheripheral on board.
This isnt an attack on your project of any sort! It was just an outloud thought. I wonder either this trend is going to change anysoon.
radu.motisan wrote 2 months ago 1 point
Most likely yes, as things evolve, despite there being a rather large inertia on change. Personally I opted for this combination based on previous experience, and for this project there so many obstacles - I had to choose things I knew they would work straight ahead, where possible.
