Bucharest, Romania and Calgary, Canada on the map
A project log for Global radiation monitoring network
The uRADMonitor is a plug-and-play, low power, self contained radiation monitoring device, connected to a centralised server component.
radu-motisanRadu Motisan 11/15/2014 at 11:360 Comments
14_11_15_header
Almost each day a new station goes online in an arbitrary location on the radiation map. The new station in Bucharest is the first of its kind right in Romania's capital city, while the one in Calgary, is the first uRADMonitor unit in Canada.
For now both are indicating normal readings and let's hope they will always will.
1100002C 11000011
Detailed measurements can be accessed on the radiation web portal.
