Norway joining the network
A project log for Global radiation monitoring network
The uRADMonitor is a plug-and-play, low power, self contained radiation monitoring device, connected to a centralised server component.
radu-motisanRadu Motisan 11/18/2014 at 11:340 Comments
14_11_18_header
Two units went online in Norway, the 11000016 in Oslo, and the 11000013 in Sandefjord.
The measurements show higher readings compared to the tests performed in Timisoara:
11000016 11000013
The Northern Europe seems to have a relatively higher background radiation. Here is a map that shows some of the background radiation levels measured across parts of Europe. Much of this is due to the radon:
NaturalbackgroundradiationEurope
Source and more details, here.
