uRADMonitor KIT1
A project log for Global radiation monitoring network
The uRADMonitor is a plug-and-play, low power, self contained radiation monitoring device, connected to a centralised server component.
radu-motisanRadu Motisan 03/08/2015 at 14:480 Comments
uradmonitor-kit1-pcbtop
uRADMonitor KIT1 is the first open source DIY dosimeter KIT, that can be used to collect radiation measurements and push them to the uRADMonitor network. Similar to model B that is to be released later this year, the KIT1 is intended for those interested in building their own radiation devices and contribute to the uRADMonitor network.
The device was designed so that it an be easily reproduced by DIY enthusiasts. It features a single layer PCB and solely trough hole components.
uradmonitor-diy-kit-06
The PCB file, and the firmware source code are available on the project's page: http://www.pocketmagic.net/diy-dosimeter-geiger-counter-kit/ . The code is hosted both on Google code and Github, all those interested are welcome to contribute.
