Become a member to follow this project and don't miss any updates
OSRC - Open Source Remote Control
An Open Source Remote Control system, designed for drone, robot and other system manipulation.
25 254 282
Share on twitter   Share on Facebook
This project was created on 07/09/2014 and last updated 2 days ago.
Description
Every single project i ever done has always been Open Source. No matter the complexity or time and effort i put into it.
Thought that went into building OSRC has been an accumulation of ideas and applications wanted for a very long period of time by both professionals as well as hobby enthusiasts. With an almost every day advancement in technology it was inevitable for OSRC to be born. The OSRC team is mostly assembled from RC users who use planes, cars and other vehicles not only for enjoyment and personal pleasure but also for professional results in the video as well as Sport industries. Taking into consideration that an RC system has to be as flexible and innovative as possible, there are endless possibilities for customization, upgrades and new features with the Main Unit alone. Combined with powerful devices such as the FPVC, Sensor and other modules it is truly a marvel for any user who becomes a part of the OSRC family.
Details
Below is an introduction video for the Hackaday contest.
Following the Semi-Finals rules, here is the 5 minute video of "What Works and What Doesn't" as the rules state.
Here is an "Artists Rendition" of the project, as described in the rules for the Semi-Finalists round.
Below are the specifications of the OSRC device currently being developed by rdGizmo For You LTD. Please note that the specifications listed here although are to be considered Final, may change due to R&D restrains and limitations.
Processor
  • CPU Complex
    • 0.8 – 1 GHz ARM Cortex-A8
    • Vector Floating point co-processor
  • Multimedia
    • OpenGL ES 2.0 and OpenVG 1.1 hardware accelerators
    • Multi-format HD 720p video decoder and D1 video encoder hardware engine
  • Memory
    • 512MB – 2GB DDR RAM
    • 1 or 4GB NAND Flash
    • 2 - 32GB Expandable microSD
Communications
  • RF Modem (900 MHz or 2.4GHz)
  • WiFi
  • Bluetooth
  • GPS
  • Video Transfer Interface
  • Default RC Module Compatibility
  • GSM Communications
  • External GSM, RF, Video SMA Antenna Connections
Multimedia
  • 4.8” 800x480px LCD (Or similar)
  • 128x64px Monochrome Display
  • Resistive Touch screen (Both Displays)
  • Internal Speaker
  • Internal Buzzer
  • Headphone Jack (Remote Audio and other Possible Functionality)
Sensors
  • Triple Axis Accelerometer
  • Digital Compass
General
  • Self-Actuated Sticks
  • 2000 – 3300 mAh Li-Po Battery (Internal Charging)
  • Upgradable Switch or Pot
  • Removable Main display Unit
  • Thumb Sticks (For camera or other control)
  • Two Way Telemetry & Sensor Communications
Accessories
  • Power Adaptor
  • USB Cable
  • GSM, RF & Video antennas included
Operating System (OS)
  • Linux GTK Gui – At the time of this writing
Dimensions (Approx.)
  • Over-All Width: 19.5cm
  • Over-All Length: 18.5cm
  • Over-All Depth: 5.78cm
Most of the information can be found on the project website since there is lots of content posted there for everyone to see. I will try to add some info here as the project progresses.
Stick Gimbals
Stick AssemblyOne of the features that makes OSRC unique is its gimbals assembly. Since from day one, the idea behind OSRC was to create an advanced platform in every possible way, we have taken the time and designed a completely unique assembly for the most important part of the control.
The first thing to notice about the design is that both X and Y axises are supported by 4 steel ball bearings, suspending the entire motion in complete freedom and smooth operation. All of the moving parts are being touched by nothing but the bearings since the motion is being recorder by Optical encoders which read the position in increments less than 0.1mm.
The Optical Encoder technology we selected for the movement fits ideally the OSRC design as it in no way interferes while moving the stick in any direction, while providing accurate measurements every time. At the same time, since there is no friction or any sort of contact while moving the sticks, there is also almost no wear on the assembly and minimal chance of damage over time. The same technology is used in advanced robotic projects where every increment of motion is important for achieving a perfect result.
To achieve motion on each axis with the same effectiveness and flexibility, we use a completely new technique. Inside each axis of the assembly there are only 2 parts as thick as 1.6mm which produce a motion if tuned to the correct frequency. To understand this better imagine that there is a disk filled with electrically stimulated components which contract if a current is applied to them. Combined in a circle they produce a moving wave that pulls whatever comes in contact with it. This technique take up less than a centimeter of space and can produce as well as simulate motion like a Ratchet effect of the stick as well as Spring response without actually having any one of them installed.
Assembly Drawing
To visualize the internal assembly better and understand what actually is going on inside each stick, take a look at the drawing on your left, which represents internal workings of the design. As you can see, the design is quite simple and yet very...
Components
  • 127 × SMD Resistors 603, 402, 805 and other packages
  • 67 × SMD Capacitors Radial, 603 and other packages
  • 351 × Diodes, LED's, Mosfets, Transistors, Inductors, Crystals Peripheral components
  • 32 × Semiconductors Microcontrollers, Voltage Regulators and other peripherals
  • 247 × Buttons, Connectors, Sockets Ribbon, USB, double Way and other connectors, switches & wires
  • 16 × Modules, LCD's, Antennas, Batteries RF Modules, Chip or external antennas and other major components
  • 45 × Enclosure & Mechanical parts Internal components, external enclosures & peripherals
  • 32 × PCB's PCB's with 1, 2 or even 8 layers for the more complex modules
Project logs
  • What Works and what Doesn't
    2 days ago • 0 comments
    Based on the requirements for the Semifinalists, i created the 5 minute video explaining the state of the project. Since OSRC has been in development for quite some time, it is no longer at a "Proof of Concept" state and is closer to a finalized product with all its initial functions operational and explained in detail on the OSRC website.
    In any case the video should be informative for those who have been following the project for a while as well as for those who are just getting familiar with it.
  • Rendition
    12 days ago • 0 comments
    Well the rules say to make an "Artists Rendition" for the project. Since OSRC is already at its final stage i wasn't sure what exactly to make but in any case i made a small sketch to comply with the rules. I'm not much of an artist so be gentle :)
  • Artist’s rendition
    22 days ago • 4 comments
    In the rules for the next round of the contest there is a section that asks the project creator to "Post an artist’s rendition of the “productized” design/look and feel of the project"
    Just to be clear, this is basically a document i should write about how i see the OSRC project from an "Artistic" point of view? If anyone has any input on this i would really appreciate the help :)
    Also another question to the competition committee, as far as videos go, am i good for the next round? I mean i already have lots of videos explaining the project as well as showing it in action. Is there a need to create another video approx. 5 minutes long to basically describe the same thing?
View all 8 project logs
Adam wrote 12 days ago null point
The reconfigurable control stick actuators are really interesting on this. Is there a name for the the type of actuator you are using?
Are you sure? [yes] / [no]
Demetris Zavorotnitsienko wrote 11 days ago null point
Thank you :) No name for it though. Just "Modular Gimbals" i guess :)
Jasmine wrote a month ago null point
Hello Demetris Zavorotnitsienko,
It's a great project and you have obviously spent a lot of time working on it over the last few years. The reason why we need you to document it here is so we can easily assess and compare to the other projects entered. It's a small price to pay for the opportunity of winning the The Hackaday Prize.
Just to make sure all your bases are covered, and you give your project the best chance - Please make sure you have the following by August 20th:
- A video around 2 minutes long briefly describing your project. Put it on YouTube (or Youku), and add it as an external link on your project page. (I can only find much more detailed videos, which unfortunately we may not have time to review)
- At least 4 Project Logs ( You've got this covered)
- A system design document (Please make this obvious in your details section)
- Links to code repositories, and remember to mention any licenses or permissions needed for your project. For example, if you are using software libraries you need to document that information. (You can outline these in your details section, and link to repositories/libraries in the external links).
Thank you for entering,
Jasmine
Demetris Zavorotnitsienko wrote a month ago null point
Sorry that the videos are too long and detailed for you. I shall try to make a smaller one just for this purpose. I read the System design Doc info but it states that the document should describe what is working and what is not.. Well the whole system is already working so i am not sure what i should write there. As far as the components used, i could post a BOM but i already outlines the parts used below in this description.
As far as software goes, i wrote everything my self so there are no libraries to speak off except for Linux which obviously wasn't written by me except the drivers integration for the hardware.
Video Uploaded and updated in the project description. Hope you like it :)
Is it ok that the Video is 3 minutes instead of 2 ?
bigbazinga wrote a month ago null point
Please provide at least a block diagram to provide more details about this:
"Due to the never seen before features we implemented in OSRC, terms such as Two Way Communication, PPM, Receiver/Transmitter, Model Count and others commonly used in the RC community, simply disappear after just a glance through the OSRC features. Both OSRC and FPVC units use many different communication techniques for short as well as long range applications. Among them the ability to transfer data through GSM networks provides the ability to control a model such as a UAV without the need for additional devices since all those devices are already built into the system."
Demetris Zavorotnitsienko wrote a month ago -1 point
I'm afraid that if i begin doing Block diagrams, there won't be any space left here :) There is plenty of information on the OSRC website, so head on there and read the descriptions for each feature. If there is something you don't understand, there is always the Forum and an E-mail.
Adam Fabio wrote 2 months ago null point
Bringing open source R/C to the masses! After decades in the hobby, it's great to see someone really pushing this. Thanks for entering The Hackaday Prize, Demetris! I've been following the OSRC project since the start. Heck, the transmitter has enough flexibility to control a flight to space! Good luck, and keep an eye on the clock - deadlines approach!
Demetris Zavorotnitsienko wrote 2 months ago null point
Thank you Adam, truly hope the project wins.
CombatCaptured wrote 2 months ago null point
An amazing concept and follow through!
Thank you :)
sifi wrote 2 months ago null point
Love it. I could see my self contributing.
Tiago wrote 2 months ago null point
Gave you the 100th skull, good luck with your project, looks really cool!
Thank you for that, really appreciate the support, i really do.
pfeffer.marius wrote 2 months ago null point
Is OSRC also Open Hardware ?
Yes it is. That's also one of the criteria for the Hack A Day contest.
Seems you are correct. It also seems that the voting is completely at random or completely under the control of the organizers? I'm not sure how it works or how people are supposed to vote if only 2 projects pop up at a time at random on the Voting page. In any case, the project was submitted. I just hope people can figure it out and hope for the best i guess.
Well in either case i think it shouldn't be difficult since it is pointed out for everyone. Others get votes so i assume everyone can figure it out.
Sergios Zafeiropoulos wrote 2 months ago null point
I did both Demitris i wish you all the best and i hope you win so it will be more affordable ....
Thank you.
dehalo wrote 2 months ago 1 point
Can you provide a linkt to your "projecto" website
Where can I vote
PointyOintment wrote 2 months ago null point
Voting is here: http://hackaday.io/prize/vote
You can refresh to get a different pair of projects to choose from.
I think the amount of "Skulls" is the voting process. Just click below the project image to vote.
PointyOintment wrote 2 months ago 1 point
Skulls don't count for the contest as far as I know. The contest voting system is separate from the skull counts to avoid popularity bias.
