ESP 8266 as plant monitor system.
New boards ready. It can read data from GROVE interface and control the pump by relay.
Can be bought from tindie
Tindie product
Source code is on the github
https://github.com/victor999/plant_monitor_esp8266
Board for measuring moisture with FDS-100 (4-20 mA version) or with any I2C sensor can be purchased at tindie
https://www.tindie.com/products/Cemb/esp8266-extension/
Designing the second part of the system: pump controller. The device will receive the data from the Thingspeak and control the water pump.
Added webserver for setting parameters for the Thingspeak.
And most important feature is remote firmware update, by the webpage.
Useful library is ESP8266HTTPUpdateServer.h
The board is up and running. Sensor output measures by analog input of ESP8266.
Useful library: thingspeak-arduino
View all 6 project logs
DARK-labs
kq
Bilal Mahmoud
Saabman
Yes, delete it Cancel
You are about to report the project "IOT plant monitor", please tell us the reason.
