Guitar Rig 5 DIY Foot Pedal Controller
Arduino-Powered Footpedal that changes Guitar Rig Presets on the Fly!
My father recently acquired an electric guitar, which he has been happily using in combination with Guitar Rig 5 (a guitar pedal/amp simulation software), a Behringer UCG102 guitar link, and a Lenovo miix tab 2. Unfortunately, this also comes with a downside.
Due to the very nature of the setup, changing presets/pedals in real time while playing is not something that is easy to do with a tablet. While it is possible to assign keyboard shortcuts to various presets, trying to hit a key on a keyboard and play at the same time is not so easy. Commercial Foot pedals that control Guitar Rig are available, but are difficult to find and very expensive ($300)!
By creating my own footpedal that uses an ATMEGA32U4 acting as a HID keyboard, I can have my own customizable footpedal for less that $20! Plus I can program all the lights, buttons, and switches in anyway I want!
A simple controller like mine can be built for well under $20, including the enclosure!  Now no offense to Arduino; they make some great stuff, but I think even the most loyal customers must agree that they charge a pretty hefty premium for their products.  But as long as you are willing to wait a while to get the parts, some Arduino Pro Micros with usb hid support can be found for as little as 7$ on Ebay.   Make SURE to order the ones with the newer ATMEGA32U4 chip, not the ATMEGA328 like the pro mini which is cheaper, otherwise usb emulation will not work without extra parts and more headaches.
I wanted to make a controller with four buttons, which could then be expanded up to 12 presets by hitting more than one button at once.  A nice led indicator would also be necessary to indicate what preset you are currently on.  A resistor ladder was used to connect the buttons and free up pins.   If you do create a resistor ladder, make sure to wire the buttons with different resistor values if you want to be able to distinguish multiple button presses at once. I used 220, 390, 680, and 2.2k ohm resistors to ensure adequate separation between the buttons and used a 1K resistor to tie the analog pin to ground.  As with everything in programming, there are always 100 different ways to do the same thing, but I wanted something a little more elegant than just using digital writes to turn leds on and off. Seeing as I had nice clear colored leds, I figured a pwm cycled sine wave would provide a pleasing fading effect to the leds. To do this, I had the buttons switch boolean values on and off which then triggered the key presses and leds, otherwise the fading effect would stop as soon as you let go of the momentary switch. That's enough talking, lets see how it works shall we?
The LEDs In ACTION!
The Inside of the Box (Please Excuse the Point to Point Wiring!)
The Arduino Pro Micro
The Momentary Switches
THE FULL SETUP!
The box was purchased at radio shack, and the leds/resistors/grommets were bought at Tayda Electronics. I recommend you use 1% resistors instead of 5%, or you may need to change the values in the matrix of my code slightly.
VIDEO HERE:
  • 1 × Arduino Pro Micro
  • 1 × Plastic Enclosure Box
  • 1 × Micro USB to Full USB cord
  • 4 × Led's of your choice
  • 4 × Current Limiting Resistors for the Leds
View all 7 components
  • 1
    Step 1
    For the Full code and Writeup, please visit
    https://sites.google.com/site/mtthacks/
View all instructions
