0x05ECure - Cryptography over BLE
A bluetooth le security dongle or SPI component. Holds the private keys away from the computer and does the hard parts of PKI for you.
0x05ECure is a project to return privacy to everyone through cheap and easy to use cryptography. The basic idea is to implement a PGP-esque trust web made with asymmetric key pairs representing relationships - be that human, human or human, machine or whatever. The 0x0 (a widget that sits on your key ring) is responsible for holding these key pairs; extracting the session key for a message we have received and passing it back to the phone to do the session decryption. A more detailed software architecture is one of the external links :)
I've not got much hardware experience and between that and wanting to make it cheap/accessible I'm trying to do as little "making" as possible. And get help :)
The 0x05ECure (ock-so secure) project aims to get superb quality cryptography into the hands of everyone or as a part of everything. As a part of this broad aim all source code, schematics and protocol documentation will be open.
The plan at this point is to make either a WiFi or Bluetooth device that can be kept in your pocket (or on a key ring) that holds key pairs and performs PKI encryption away from the client device. I will also port the code onto the LPC1114 (a dip packaged Cortex-M0) such that it can become an SPI connected standard component for IoT projects. Libraries will be written for the 'phone/tablet' use case - at this point likely as a plugin for Apache Cordova - and an Arduino library for the IoT use cases.
The API itself will consist of relationships - a concept which encompasses asymmetric key encryption between two nodes; messages which are two part (ECC and AES) blobs that require the device to authenticate and recover the session key so the client can do the stream decryption; and a presence/transport API for moving the messages themselves. A small server side presence server may become necessary ... or I might just use XMPP.
  • 1 × nRF51822 Bluetooth LE tranceiver with software stack.
  • Ooooookaaaayyyyy
    David Preece10/24/2014 at 22:08 0 comments
    So, bummer. I've been lucky enough to bring a truly talented cofounder on board and she's pointed out that people 'aint going to want to carry this thing around ... so we're knocking this on the head.
    The good news is one of the reasons is there's a good *enough* messaging app called Telegram (http://telegram.org/). If you want security - use that.
  • Not dead
    David Preece09/30/2014 at 21:39 0 comments
    I'm not dead, I just got pissy when failing to get to the next round of the Hackaday prize. Oh well.
    Development continues ... some projects have been made, explored, and ultimately thrown in the bin although I feel like I'm now on the right track (https://github.com/RantyDave/oxo) where the golden knowledge is really the links to the Nordic team in mbed (http://mbed.org/teams/Nordic-Semiconductor/code/nRF51822/) and the Bluetooth team (http://mbed.org/teams/Bluetooth-Low-Energy/code/BLE_API/). I *had* a fix for them but someone got to it before I did :)
    My impressedness with mbed continues and I think long term it deserves to be embraced more thoroughly. I hadn't realised it's formally backed by ARM, although I wonder about whether or not ARM should be doing this *and* the CMSIS thing (http://www.arm.com/products/processors/cortex-m/cortex-microcontroller-software-interface-standard.php). As far as I can tell CMSIS is more "pro" level (not that I've found anything particularly wrong with mbed) and I suspect C only.
    Speaking of which, as you might've gathered my attempts to embrace ye-olde C-e have not gone very well. Nordic's sample code is knee deep in copy/paste's and things that need to have 'init' manually called and I just don't do that shit any more. It does have a malloc, which means 'new' works but rather ominously it is possible for the 'growing down' heap to hit the 'growing up' stack with "undefined" results. Hmmm.
    The major challenge right now is to get the phone to even realise the nrf even exists. Since other software on the phone *can* see it, this is not going to prove to be impossible although 'time consuming' reserves it's right to bugger things up. As always.
  • A C++ framework you say?
    David Preece09/06/2014 at 02:34 0 comments
    Just a quickie today: while building a C++ framework for BLE I discovered there's one already :) So god bless mbed and their bluetooth team (http://mbed.org/teams/Bluetooth-Low-Energy/).
    Mbed itself is weird until you get the idea then it's awesome. It has one of those (dreaded) online IDE things and theirs is really quite crap. It does, however, set up projects their dependencies etc. and can export to all the major embedded development environments. So that's what I've been doing ... and developing in Keil which despite how ancient it looks and behaves does at least have the advantage of working properly.
    Oh, and the online build is excellent. Very very impressed by that. I wonder if it's possible to wrap a real IDE (and debugger) around their setup and compile infrastructure. Hmmmmm.
  • Licking my wounds
    David Preece09/02/2014 at 20:02 0 comments
    Sorry it's all gone quiet - I've been licking my wounds after not getting through to the next round of the hackaday prize. Rant rant rant.
    In the meanwhile, 3 days/week has become 0 days/week so I get a chance to get this going. I've been almost successfully mucking around with the nRF, getting new code to compile and what have you. It's a *moderately* complicated API but if you look at what it does (lots of async) then you couldn't really make it simpler. I think I'll put together a simple C++ framework for building services just so I can clean the code up.
    Also: Apache Cordova. Or, rather, PhoneGap that for some reason I seem to have more luck with. It's been going well: I've been playing with a BluetoothLE plugin and, again, kinda complicated due to the amount of async involved. However, it appears that cordova plugins are really quite easy to write so I might just make an 0x05ecure plugin: it would be (I think) easier to develop because I'm more comfortable in Objective C than Javascript; and it would make it easier for third parties to integrate into projects. So, yes, that's it. That's what I'm doing today :)
  • 32 minutes
    David Preece08/21/2014 at 06:17 0 comments
    The counter on the homepage says I have 32 minutes. Everything (for this stage) is done but it doesn't stop me from sitting here shitting myself :)
  • Power
    David Preece08/19/2014 at 19:58 0 comments
    I've always been bugged about the power for this. For a start, whether or not BLE will 'work' makes the decision between BLE and WiFi. But for now let's assume BLE is a goer. There's lots of talk of a one year battery life and that a CR2032 would be sufficient. An extra bonus from this is that there are a *lot* of CR2032 plus 'one or two buttons' cases being manufactured for the car security market. A better solution might be to use a AAA battery but that then gets really messy around nasty plastic cases screwed onto motherboards and all that yuckiness. I'm currently wondering about using Chinese 'promotional' keychain torches (i.e. http://bit.ly/1pHw4WV) and probably replacing the led end with the radio gear buried in injection moulded plastic. But still screw on/off so we can change the battery.
    The other alternative is energy harvesting. Unfortunately this is not a cheap pastime ... TI publish a reference design for a BLE sensor with solar energy harvesting http://www.ti.com/lit/ug/tidu235/tidu235.pdf but it's *huge* and presumably very expensive. I was hoping that a small (25x10mm) solar panel with power management and a small LiPoly would be sufficient but it's beginning to look like (a) it might not be and (b) it'll be a *lot* cheaper to rely on replaceable batteries. I imagine a AAA stores many more joules than a CR2032 while still not being embarrassingly large (although any bigger may well be).
  • Oh great, toasted my Windows install
    David Preece08/16/2014 at 00:17 1 comment
    As per subject a reasonable amount of time was spent getting depressed. I moved it (a virtual hdd file) from my Apple SSD onto a Transcend JetFlash since space is getting a little short ... and soon after it faceplanted. I have no idea if the two are linked.
    The good news is I found an *amazing* piece of software for working with Jquery Mobile. http://handhelddesigner.com/ is so, so worth the money. Almost VB like in it's simplicity. Yeah, I had fun with that :) Now for attempting to build http://handhelddesigner.com/ with a bluetooth le plugin then calling it. Hmmm.
  • Videos!
    David Preece08/09/2014 at 21:32 1 comment
    Because it's not all fun and games, this week I got kinda stuck doing an explainer video (which, hopefully, is now somewhere up there ^ on this page). I used this software called videoscribe which is the oddest thing ever... It's a genius piece of requirements capture and 'paring back' the options to make a great user experience - which is then totally ruined by (I think) Adobe air. It's slow; saves and loads very unreliably; and all the keys are wrong - undo is not cmd+z, for instance.
    So, a sh!tty update but then I didn't get to play around with wires and stuff this week. Mind you, it's only Sunday morning ... wonder if I can sneak some in :)
  • Well, that hurt
    David Preece07/31/2014 at 20:48 2 comments
    So, interviewing the nRF51822 - a chip famous for being hackable-as - using the official "evaluation kit". Which means a development kit but not as expensive as the actual development kit.
    I "out the boxed" it a few days ago, did what the instructions said and had it doing it's funky thing within minutes. Unfortunately it uses the Keil IDE which at $4k/seat is not really a hobbyist solution but there is "support" for Eclipse. Oh yes. Support. There's lots of moving SDK's to non-default locations, download bits and pieces and gluing them together in Eclipse ... however, it at least appears to work. But, ignore the man behind the curtain! Of the provided examples only one ships with an Eclipse project and it just happens to be the one used in the tutorial. Creating a project? Compiling? Uploading? Up to you, matey. The makefiles appear well written but documentation is more or less zero. I had a shit of a time getting it to compile and go, and the feeling that when something goes wrong I'm going to end up blaming my really-quite-clueless bumbling around inside makefiles as the cause. Damn.
    So today I'll try Keil again. You can rent it for $1500/year and if I'm actually putting some serious time into this I'm not a damn hobbyist :) I also reckon Keil is a better investment than yet another 3d printer. More security devices, fewer plastic bunnies.
  • Front runners
    David Preece07/23/2014 at 22:53 0 comments
    Just a quick note on hardware trials thus far:
    * Broadcom BCM43362 (http://community.broadcom.com/docs/DOC-1422). Despite putting a Cortex-M3 in there, Broadcom really do not want you to hack on this chip. A shame since I'm trying to do it in a single component. That being said it does appear to be more than competent, if a tad expensive and with a slightly bizarre development environment. It can also - and this is really cool - be an AP and an STA simultaneously. I may yet get involved with proxying between two wireless networks :)
    * TI CC3200 (http://www.ti.com/product/cc3200) is kinda wonderful. Unlike the Broadcom chip, this one is very much a single chip solution. Out of the box it runs an AP with a web application on it. Everything just works. If it wasn't for a moment of clarity in which I realised Bluetooth LE *would* be good enough, I'd be working with it today.
    * Nordic nRF51822 (http://www.nordicsemi.com/eng/Products/Bluetooth-Smart-Bluetooth-low-energy/nRF51822) is another *begging* to be hacked single chip solution. Significantly down on processing power from the WiFi chips, as you can imagine, but seems at least likely to be *enough*. I've only just started working on it and while the dreaded Keil is supported there are also guides for using gcc+eclipse. Getting this going is today's work...
View all 10 project logs
David Preece wrote 08/19/2014 at 19:31 point
Thanks. I *think* I've got it right :)
Regarding BLE security: it can bind itself to a particular client (i.e. phone) and will then use AES128 to encrypt resulting conversations. I'm sure it helps that the transmission power involved is really low too. Finally the best result you can get from even plaintext sniffing would be the ECC 'envelope' for a message (not useful) and on return an AES key that is valid for only that one message. It's something I want to look into more though...
davedarko wrote 08/21/2014 at 19:05 point
https://www.dropbox.com/s/txjg6tn4sqs12fs/Screenshot%202014-08-21%2020.52.17.png
I would not call this a pitching picture ;) with 2833 projects this will be interesting in the future, how one get attention to his/her projects.
I did a quick wikipedia read on that, seems quite safe, but then again - i have no idea :)
davedarko wrote 08/12/2014 at 11:50 point
Hey, came here from the stack page, let me try to help you with your PR ;) When someone sees your project in a list, he/she will only see the title and a picture, which would be in your case 0x05ECure and a chip. It lacks a pitch/eye-catcher, something that gets you attention like "BT encryption key dongle: 0x05ECure" but watch out, since you don't have many letters (one row) you should make a really easy to get picture and check the picture in all places - they are sometimes cut off. I did not get the leet part at first either - might be a clever name but doesn't promote its function.
Interesting project, I will follow that :) I don't have any experiences with bluetooth, so hope you don't mind me asking... is bluetooth safe for this? I've seen BLE and NRF24L01 communications been recorded with a mmds down converter with a rtl-sdr and wondered...
