This project is set up to trigger a servo every time the cloudBit receives a pulse though IFTTT’s Instagram channel. IFTTT is a service that lets you connect to different web apps through simple conditional statements. When the cloudBit is triggered, the servo pulls down on a hose connected to the nozzle of a helium tank, releasing helium into a balloon. Any time a user hashtags a name of your choosing, a trigger is sent to IFTTT, which in turn sends an output signal to the cloudBit. Bask in your glory and float on!
