Become a member to follow this project and don't miss any updates
Lazy Killer 9000
I'm tired of flying insects and chasing after them....
This project was created on 08/01/2014 and last updated 7 months ago.
Description
Instead of chasing insects with your swatter they now will die by self inflicted electrocution with out any effort on your part. It's an electrified hat with web based capabilities. State of the art embedded technology allows for remote on/off , available kill power, and of course a kill counter. The overall goal will be to have a network of these devices that a user could control from any location once the device has been positioned.
Oh.. all small print legal jargon here about shocking, injuring, killing, and all other possibilities to yourself or others not being my fault due to your incompetence or mine. Proceed at your own risk!
Details
License
DONE!!!! Finally have my 2min video although I need to learn how to edit videos properly.
Overview diagrams
First component located.
Kids left it in the wrong place so I claimed it.
2nd/3rd components have been found.  One was behind a counter and the other in IC land.
Gut the zapper and form the base for the zapper on the hat.
Solder the cut edges the best you can after slightly forming it your head.  This electrode is a few inches short so may need to buy some more if this works.
Tried to tie the electrode spacer but that was taking too long so I resorted to good 'ol messy hot glue.  Takes about 5-6ft of 3mm PLA to make the spacer (It was EXACT thickness of the spacer included withe the original swatter.  Design is different from front to back to see what was easier.  The back was about 10 times quicker and next time everything will be folded.
Add top electrode via more hot glue and 10-12ft of 18ga solid copper wire.   I didn't have one contiguous piece so I will be soldering pieces.
OK folks I was able to complete the electrocution hardware today and will move into the fun part of getting the arduino up and running on this.  Was great after slaving in brew land and bbq land I was able to capture this wonderful moment. FIRSTTTT KILLLL! (took 1 minute.).  Apologies in advance for poor video quality.  I might go charge the real camcorder now to get 1080P and video that is not moving all over with my thoughts.
Yes, it does have a magic wand attached via some alarm wiring...  Will figure that part out later once I have software working.
  I didn't feel like messing with a voltage divider and really did not want 500V near the Arduino so I switched places.  I take a pic in a few of the new location and components added to make it work.  I can say that now the Arduino is looking at 1-2 volts (3 max) and the code can distinguish between on/zap/off (working on zap still and stuck zap).  Here is some data dumps from the program charted in excel.
I do not know how this worked but I can tell you my method. 1.) find a small volt supply that fluctuates with zaps. 2.) added blue cap in picture and zapper stopped working.  My theory was the zapper was using the cap instead of dumping everything to the short.  So I found a diode and put it in thinking that would allow the voltage to flow in but not back out.  WORKED!  The data values were still jumping all over so I added the round disk cap and BAM the excel charts above.  I may add a resistor later to make the caps discharge faster but I want to get the proto working and will deal with that later.  New watch place in yellow
Code working on state detection and outputting JSON data.  Next step is web side. VOLUME WARNING @ 0:20.  Dog hates the zapping sound, must be having some flashbacks...
Components
  • 1 × Hat Any hat, baseball, cowboy, beret, sombrero
  • 2 × Batteries Electrocution takes power so choose wisely (D)
  • 1 × Electric fly swatter http://www.harborfreight.com/electronic-fly-swatter-40122.html
  • 1 × wifi arduino It's what I have. Once I have prototype working I will purchse a smaller wifi enabled device.
  • 6 × feet of 3mm PLA Weed-eatre line will work as well. Just need a gap..
  • 1 × Hot Glue Gun
  • 12 × feet of 18ga solid copper wire
  • 4 × feet of alarm wire. Any 2 conductor wire about the size of alarm wire would work.
  • 1 × .001K 1KV ceramic capacitor Looks round and brown. Back says Mexico Z5F
  • 1 × 100µF 10V fixed capacitor
See all components
Project logs
  • Getting back at it
    7 months ago • 0 comments
    Been working on adding a DRO to the mill and since that is complete I am ready to get back at this project and get this POC2 completed.  Will be adding the light and some sort of module to detect the presence of a pest. microphones(autozap), capactive touch, etc...
  • What did I build? Investigation time
    Yesterday and today I broke out my favorite electronic books to try and understand the diode capacitor relationship I built.  Was my logic in use correct?  Does it have a name?   My guess is that this is a transient circuit since we have .."a sudden change in voltage introduced by an external agent...", aka Mr. Fly being electrocuted.  Book has some formulas to model this behavior which I will look into once I have POC2 up and running.
    I will map the complete circuit but this is what I understand.
    1.) The diode does act in the way I intended, one way current/voltage flow.  Learned it has a -0.6V drop when in series like I placed it.  Since I might be tapping off the transformer it could act as a 1/2 wave rectifier as well.
    2.) The electrolytic capacitor that is inline with the diode does charge like I expected.  The closest thing I could find is it is a capacitor under forced response.
    3.) The ceramic just helps even things out a little, bypass circuit to get rid of some undesired ripple.  Also drains the electrolytic cap. since the ceramic is connect to ground.
    NEW IDEA--> Maybe putting a resistor in parallel with the ceramic will help the electrolytic drain faster and give a snappier recharge picture.  Also may add a resistor before the diode to get the voltage  < 1.1 so I can switch the Arduino ADC over to 1.1 reference instead of 5V reference.  Since I have been testing with a piece of wire I have a feeling a fly will not pull as much a load as my test wire.  I could be wrong since a short is a short and as long as the short does not break then we should have the same results.
  • Found the zap moment
    8 months ago • 0 comments
    Spent a good hour looking around the charging board for a easy way to detect a strike and give feedback for a "stuck bug".  Turns out a cap just after the transformer works great!  Noisy circuit is all I will say, everything had noise (not little noise either).
    I also contemplated making a network of this zappers for my yard (found my XBee's) but I need this prototype working first.
View all 9 project logs
Build instructions
  • 1
    See details section until I can move them down here
See all instructions
MF Jones wrote 8 months ago point
Awesome, I like the light idea as well. Can u figure out how to make a design that attracts Mosquitos. I like when those die...
Are you sure? [yes] / [no]
BDM wrote 8 months ago point
Sounds like need to find some "bait" packets to go under the trap. Thanks for the skull and follow.
DainBramage wrote 8 months ago point
Electric bug zappers are awesome. I turned mine into a DIY stun gun. :)
Arduino is for phase 2, stay tuned. I want to use a smaller device but for the prototype the blackwidow arduino is what I had laying around.
Professor Fartsparkles wrote 8 months ago point
What do you need an Arduino for? Do you want to save power by toggling the power for the swatter?
Great idea though, maybe also ad a light behind the swatter so its super effective at night.
Similar projects
