E-Paper display, Arduino compatible/Shield conference badge
I don't know if this project is still active, but i wrote a WIF image creator / editor in C# for windows using an image manipulation library and it's Open Source, no releases, as it's only really designed to work if you know it's going to crash every now and then.
Contributions are welcome:
Hi, I'll ask Justin and Kevin (who work on the code) to check it out.
Hi David, all of us at WyoLum use Linux so we aren't of much help trying out your Windows based Wif generator. We'll paste a link on our projects page so others can try it out. Thanks for whipping this up.
Hi Anool, I seem to have physically damaged my display panel. Is the display on the badger (received at OSHWS 2013) the same as or compatible with the ePaper 2.7 screen from Adafruit / RePaper?
http://www.adafruit.com/products/1346
Yes, to answer my own question... (I should have checked the site)
http://wyolum.com/projects/badger/
Repaper.org's amazing electronic paper display EPD (made by Pervasive Displays Inc.). A huge shout out to the generous support we have received from them. We simply could not have offered this badge without them.
Looks Awesome!
