Become a member to follow this project and don't miss any updates
ooklone
a cheap RF 433.92MHz OOK frame cloner
This project was created on 08/12/2014 and last updated 4 months ago.
Description
The OOKLONE device allows you to capture RF signals (or frames) from equipments operating on the 433.92MHz frequency, and replay them at a later time. This way, you can clone the original equipment functionality. Such equipments include device remote controllers. Please see the following videos for examples including wireless wall outlets and car door locks:
http://youtu.be/LgjCQ955Rmc
http://youtu.be/40qgGdyqTsA
In its current implementation, the device includes:
. standalone power supply using 3x LR03 batteries,
. a flash memory to store the captured frames,
. a selection switch to select the frame,
. 2 buttons for playing and recording frames,
. a serial link for development purposes.
A next iteration of the device will focus on implementing mechanisms to defeat anti replay schemes in some extent. Also, proper schematics and CAO files for a 3D printed case will be added.
Details
The initial device prototyping and first tests are detailed in a blog post here:
http://www.embeddedrelated.com/showarticle/626.php
System block diagram
User interface
Materials
The device firmware and related tools source code are available in the GITHUB repository. Final schematics and CAO for a 3D printed case are still to be done.
Logo
Here are some possible logo. This is work in progress, you can find the GIMP files on GITHUB. Let me know which one you prefer or if you have your own proposal.
doc/logo/0001:
doc/logo/0002:
doc/logo/0003:
Components
  • 1 × MOTEINO board with RFM69 option handle signal capture, pulse slicing and replay
  • 1 × lm317 Power Management ICs / Linear Voltage Regulators and LDOs
  • 3 × LR03 batteries batteries
  • 2 × buttons record and play a frame
  • 1 × switch turn the power on off
  • 1 × SMA femal connector allow for testing different antenna
  • 1 × 433MHz SMA antenna antenna
  • 3 × capacitors (2x 470uF, 1x 100nF) tank caps
  • 1 × VELLEMAN ABS box
  • 1 × LR03 batteries holder
See all components
Project logs
  • assembled v0000 PCBs
    4 months ago • 0 comments
    I received PCB v0000 from SEEEDSTUDIO and components. SMA signals are reversed,, making the SMA connected antenna useless. I suggest to use a 17.3cm wire instead. This has been fixed in PCB v0001. I tested the board only with USB power, waiting for the enclosure to arrive to finish tests.
    Pictures:
  • Enclosure files
    Finished the enclosure modeling, in SOLIDWORKS. STL files available. Sent to SEEEDSTUDIO for 3D printing ... will post the results when available.
  • Eagle schematics
    5 months ago • 0 comments
    Eagle schematics published, still to be tested. The PCB is 50x50mm 2 layers to fit the Seeedstudio requirements. Batch sent, more news when received.
View all 12 project logs
tremmert wrote 5 months ago null point
I probably should have waited for your results from seedstudio, but I went ahead and sent your sch files over OshPark. Ill post my results once I receive the PCB in the mail. I look forward to testing your OOKlone unit and experimenting with anti replay circuits. As your time permits, please continue to post updates, this project has me really excited! Thanks for your hard work!
Are you sure? [yes] / [no]
texane wrote 5 months ago null point
I hope the PCB is correct ... I did not have as much time as I wanted to review everything in details and there were some tradeoffs to make it fit the 50x50mm frame. I will post results, please let me know yours.
tremmert wrote 4 months ago 1 point
PC Boards arrived today. Still waiting on the components to come in the mail...
texane wrote 4 months ago null point
Ok, let me know when you have completed it. Mine should arrive soon too, this week I hope.
naroom wrote 5 months ago null point
Awesome project! This has been my favorite on HaD projects so far. The demo videos are excellent. I'm surprised you didn't get into the semifinals, but the projects that made it were pretty nuts too. Anyway, I hope you keep working on this project! I'd love to see how it develops.
Thanks for the support. As you said, projects that made it are generally very good at least, so I am not surprised OOKLONE was not selected, even if I hoped it would have been :) I have a few features to add, plus schematics and possibly a 3D printed case, so stay tuned :)
Austin wrote 6 months ago null point
Really excited to see where this project goes. Ill be buying components and testing this myself.
texane wrote 6 months ago null point
Thanks for your interest. I will make a cleaner and more complete version after I played a bit with the prototype. The core component will still be a RFM69 chipset. I may change the ATMEGA328 for a CORTEX, but will try to keep the code portable. Stay tuned !
Gabriel wrote 6 months ago null point
I curious as to how the data comes out of the RF module... is it noisy as with the cheaper modules? O-Scope screen shot?
Good question, I do not know about the SNR. I will have a look at the spectrum with RTLSDR and post info.
Similar projects
