assembled v0000 PCBs
A project log for ooklone
a cheap RF 433.92MHz OOK frame cloner
texanetexane 10/11/2014 at 15:550 Comments
I received PCB v0000 from SEEEDSTUDIO and components. SMA signals are reversed,, making the SMA connected antenna useless. I suggest to use a 17.3cm wire instead. This has been fixed in PCB v0001. I tested the board only with USB power, waiting for the enclosure to arrive to finish tests.
Pictures:
