TOOWHEELS badminton project plans.zipHere you can find the 2D and 3D plans of the badminton project, a custom Toowheels for the Italian Badminton Athletes with a read-me file with some instructions! Enjoy!Zip Archive - 8.77 MB - 10/09/2017 at 15:58 |
TOOWHEELS_3D PLANS.zipHere you can find the 3D plans of the wheelchair in 3dm and stl.Zip Archive - 44.67 MB - 09/28/2017 at 15:42 |
TOOWHEELS_2D PLANS.zipHere you can find the 2D plans of the wheelchair in dxf, dwg and pdf.Zip Archive - 289.27 kB - 09/28/2017 at 15:38 |
TOOWHEELS_1_project photos.pdfHere some photo of the project!Adobe Portable Document Format - 1.93 MB - 07/05/2017 at 14:06 |
TOOWHEELS_2_BOM.pdfHere the Bill of material you need to make your wheelchair.Adobe Portable Document Format - 170.19 kB - 07/05/2017 at 14:06 |
TOOWHEELS_3_INSTRUCTIONS.pdfHere you can find the step by step instruction to make your wheelchair, from the ergonomic customization to the final assembly.Adobe Portable Document Format - 3.28 MB - 07/05/2017 at 14:06 |
TOOWHEELS_5_ASSEMBLING MANUAL.pdfHere you can find the mounting drawings of all the components.Adobe Portable Document Format - 1.57 MB - 07/05/2017 at 14:06 |
TOOWHEELS_4_PRINTABLE PLANS & CUSTOMIZATION.pdfHere the plans that you can print with your home printer (ISO A4 paper size), and also the instruction to create a custom-size wheelchairAdobe Portable Document Format - 378.42 kB - 07/05/2017 at 14:06 |
TOOWHEELS_2D PLANS.dxfHere you can find the 2D digital files.AutoCAD DXF - 1.34 MB - 07/05/2017 at 17:16 |
