Remote Control Power Wheels
Taking a toy Power Wheels and making it remote control. Making improvements as time, money, and availability of parts allows.
This project started when I found a Power Wheels toy on the side of the road. I thought "That would make a fun project." The other driving force for this project is that my nephew loves ride on powered toys. He is still to young to understand steering but he has fun going in straight lines. This is where I thought, "Why cant I just take control?" So this is my log as I make improvements. The progression as it stands is to start with wire control to eventually end up with it controlled over wifi. Possibly end up being controlled over 3g with a video stream. If I get really ambitious I will add charging abilities (as in stealing from outlets wherever they may be). All the while making any improvements possible. As money and time become available this will be improved. I am doing this on here mostly for version control if you will.
The system design overview is very vague due to the nature of this project evolving so much with each project revision new overviews may be produced as necessary along with code and schematics. The first revisions goals are to not spend money, to see how well I can make it without spending money. From there it is still a cheapskate project in nature.
  • 4 × ODC-5 Optorelay thing
  • 4 × 12V 3PDT Relay Nothing special
  • 6 × Diodes Generic
  • 1 × 7805 Regulator
  • 1 × Terminal Block
View all 9 components
  • V4: Mosfet attempt
    TBJR608/19/2014 at 15:43 0 comments
    Even though I am without any type of receiver I figured I'd try to make the control board smaller. I bought mosfets with the intent of making two h-bridges. This would decrease power consumption and make everything smaller and easier to hide. Stupid me bought the wrong mosfets. I bought 8 N enhancement mosfets with too high of a switching voltage. So between the fact that half should have been P and the fact that they are too high of a switching voltage, I screwed up. I should have stuck to the plan of the wireless router and stuff, so next revision will be that.
  • V3.5 Big Oops
    TBJR608/19/2014 at 15:29 0 comments
    So the Remote control receiver has a "turbo" function. I figured I could tap into it and install horns. I thought what could go wrong? Apparently everything since I fried the chip trying to solder. I was originally hoping that V4 would be solid state using mosfets and such, but now it seems that since the control system needs attention I will be shifting my priorities to that. So time to make it WIFI controllable. My Idea is to use the serial port of a router and connect it to an MSP430. We will see how that goes.
    Purely for posterity here are the horns I was planning on installing.
  • V3: IN ACTION
    TBJR608/19/2014 at 15:11 0 comments
    I finally remembered to take video of it functioning. This car is faster than it looks. The second Video has a nice lesson on why to mount things. AKA things will be made much smaller in the next revisions. This was a quick dirty functional toy.
    http://youtu.be/H8Riyi-4NmE
    http://youtu.be/jz8rgByZZ0s
  • V3: Now With Steering
    TBJR608/19/2014 at 14:52 0 comments
    Steering was definitely an issue on this project. Skid steering was too unreliable and too unpredictable. It took me a few days to figure out the solution. The easiest way was to remove the steering wheel and attach a drill, simple enough!
    This is intended only as a temporary solution since I can't exactly fit a child in the car the way it is. Either way, drive-ability went up exponentially. It became way more fun to drive. The modifications to the wiring couldn't have been more simple. I put the two rear motors in parallel on one set of relays and the drill on the other set of relays. From there I had to turn the switch on the controller 90 degrees and it was done.
  • V2: Wheels in Motion Without the Chasing
    TBJR608/19/2014 at 14:37 0 comments
    The title stems from the fact that this revision added wireless functionality. This is the first money spent on this project. A $7 remote control toy car was purchased and torn down for its precious wireless ICs.
    Basically the parts from the RC car replaced the CAT5 cable. The transmitter was jammed inside the DPDT switch controller, and the receiver was attached to the SSRs. This was easy to accomplish. The following is the controller from a newer revision, the only difference is that the right switch is turned 90 Degrees
    The power for the RC car was designed to use 3 AA batteries. Close enough that 5 volts won't fry it. In comes the 7805 regulator to power it. The motor ICs on the original car were more than enough to power the SSRs. Thus creating revision two. It is basically the same schematic as revision 1 so I will not be redrawing it. The following is the control board installed in the car.
  • V1: Wheels In Motion
    TBJR608/19/2014 at 14:21 0 comments
    This version was mostly to test the functionality of the toy itself. This version was done completely using found parts no purchases were made in this revision.
    For this revision I wanted to keep everything simple and make sure that it moved. Since it had independent rear motors, I figured the easiest control system would be to control them independently. I later found out that the front wheels have a little too much grip for reliable control. For this log I won't be writing up any schematics unless someone asks due to the simplicity of it.
    The control was achieved through a 12V SLA battery, 4 3PDT relays, 4 Solid state relays, a few diodes, a few feet of cat5 and 2 DPDT center off momentary switches. I know that these parts are overkill, but it was what was laying around.
    Basically each motor had two relays, One for direction and one for power. Each relay was then activated by one SSR. The power fed to the controller of the two switches. The switches then fed into the SSRs. To make the motor go forward one of its relays was activated, for reverse both were. This version was purely a test. Things will eventually progress to more complex technology.
View all 6 project logs
