Bionic Yourself v2.0
A project log for Bionic Yourself V2.0
Project Bionic Yourself (B10N1C) is a small implant for your arm that makes you a bionic-superhero.
txyzinfotxyz.info 09/02/2014 at 14:150 Comments
Bionic Yourself 2.0
A smaller, simpler, more rounded enclosure design.
1. RFduino replaced on Atmega328 + NRF8001. This allows me to make the unit smaller
2. HM11 replaced on BlueGiga BLE113 (with HM10 firmware). Also used to make design smaller.
3. Removed both PCA9536. Atmega328 provides enogh pins for LED's
4. Removed the 16bit ADC AD8692ARMZ. Now utilizing the Atmega328 anolog inputs for the EMG and MEMS microphone.
5. Vibrator motor replaced for space to fit in the new unit design.
6. Voltage regulator TPS61200 replaced on the TLV70033
7. EMG ground terminal is now located on the top of the unit.
8. 316L Stainless Steel will be utilized by piercing Barbels for EMG terminals.
