• Update
    Stefan-Xp11/30/2016 at 22:52 0 comments
    I have now some new choices:
    - Find out how to call a https page with the ESP8862
    - Find a way to tell my webserver to call the https Page for me (until now no luck)
    - Create an Android App and an Webapp using FireBase and VS Studio 2015
    - - Find a way to teach the ESP8862 XMPP Protocoll or find a way to translate it to.
    - Just give up
  • First almost useful ESP8266 Testapplication
    Stefan-Xp11/23/2016 at 21:11 1 comment
    Greatly Inspired by #ESP8266 Retro Browser I have rewritten my sketch a bit :)
  • Well now it's working
    Stefan-Xp11/23/2016 at 00:08 1 comment
    Wow it is some kind of addictive ;)
  • How it is not working
    Stefan-Xp11/22/2016 at 21:47 5 comments
    I tested this Program:
  • Hello ESP8266
    Stefan-Xp11/21/2016 at 22:15 11 comments
    Today i got first contacts between ESP8266 and Arduino Uno.
    One Major drawback is, that the tx/rx is occupied by the ESP8266.
    So once you can't really see whats going on and second you can't flash the Arduino when connected.
    I added the EA DOG Shield to my Arduino to get some Response from the communication.
    But viewed from now it is still some way to go.
    I wonder if it is normal, that the ESP8266 gets hot.... i used the Schematic like from the ESP Breakoutboard.
    BTW: Don't connect USB+ and Voltages > 5V together... PC did't like it (Rebootet) but i hope no further damage is happened.
  • ESP8266 and Arduino Uno still don't want to play
    Stefan-Xp11/20/2016 at 21:45 0 comments
    As begun with https://hackaday.io/project/2746-furious-tooth-fairy-door-unlock/log/49242-time-for-a-update/discussion-69901
    I still have some plans for this project.
    • Get the Data of the alarm message from the dme. [done with Software Serial and a small circuit]
    • Set up the ESP
      • Connect via FTDI 3.3V Cable ==> works
      • Connect to Arduino UNO TX and RX ==> Do i need to switch RX and TX when using the Terminal versus when using the Uno?
      • Connect to Software Serial ==> Don't work properly .. Echo works, Responses get scrambled.. See below code (Mostly from Example) [1]
      • Tell the ESP to call a specific Website with specific received data (not begun)
    • #include <SoftwareSerial.h>
      SoftwareSerial mySerial(10, 11); // RX, TX
      void setup()
        // Open serial communications and wait for port to open:
        Serial.begin(115200);
        while (!Serial) {
          ; // wait for serial port to connect. Needed for Leonardo only
        Serial.println("Goodnight moon!");
        // set the data rate for the SoftwareSerial port
        mySerial.begin(115200);
        mySerial.println("AT");
      void loop() // run over and over
        if (mySerial.available())
          Serial.write(mySerial.read());
        if (Serial.available())
          mySerial.write(Serial.read());
    • Hmm.. maybe tomorrow i get some enlightment.
  • The 7x5 Dot Matrix LED Prototype...
    Stefan-Xp10/22/2015 at 20:47 0 comments
    So it's time to give away my prototype (I need more space) It goes to a good friend.
    So you get the Pictures of the Prototype of https://hackaday.io/project/3099/log/14142-the-7x5-dot-matrix-display
    It is a 4 Layer PCB ;-) ...
  • Well well ;-)
    Stefan-Xp09/16/2015 at 21:23 3 comments
    It looks like the Alarmierungsuhr is going to get a little Sister.
    I take some of the left over PCBs and build a Clock with will go into family with my FB 7S Clock :-)
    Nice Paint Job isn't it? ;)
  • Already well done :-D
    Stefan-Xp08/21/2014 at 20:15 0 comments
    I have to admit, that i almost finished the project before starting this HAD-Project ;-)
    Please enjoy my Video:
    Step by Step I will add a few more informations.
