4P-RGB-Strip Flex Module
A Flex Module 4 pin connector that supports RGB strips with 4 leads (as well as many other 1 or 2 pin I/O peripherals). For sale on Tindie.
Simple SMD JST XH mount for wiring LED strips from a Flex Module.
This board is part of Fyber Labs Flex Module project.
We are utilizing a generally available JST connector that supports multiple amps. We chose the 4 pin version as it will easily accommodate common 3 lead 5V RGB LED strips as well as the 4 pin versions. With some 4 pin strips this adds the ability to split and splice the strips in multiple directions using simple connectors. We will be discussing this further in the Dance Kit demo project.
Any software related will be released under BSD or MIT license. SAAS or cloud based software will be AGPL.
Creative Commons License
  • 1 × S4B-XH-SM4-TB Connectors and Accessories / Board-to-Board and Card Edge Connectors
  • R0.7
    Chris Hamilton08/17/2015 at 17:05 0 comments
    0.7 had some weirdness with a randomly rendered extra via, but it has been fixed. I believe this will be the final version of this board.
  • Updated Pictures
    Chris Hamilton12/18/2014 at 03:11 0 comments
    We are manually soldering these right now. I updated the pictures to show the new castellations and added a link to the Tindie page to buy them.
  • Dance Kit
    Chris Hamilton09/28/2014 at 23:55 0 comments
    We are releasing details on the demo project utilizing this Flex Module.  We are calling it Dance Kit.
  • Toasty
    Chris Hamilton09/04/2014 at 07:15 0 comments
    Our test reflow on the connector resulted in some toasty plastic.  We are still learning how to use our new reflow oven, so this should be solvable with a little experimentation.
View all 4 project logs
  • 1
    Step 1
    Detailed discussion of tools and process will be made on the Flex Module project.
  • 2
    Step 2
    Order board from OSHPark and solder paste stencil through OSH Stencils.
  • 3
    Step 3
    Order BOM components.
View all 5 instructions
