The WiFi Hunter
A drone based system to dynamically explore, find and record the location of WiFi networks in real time.
The drone will seek out and determine the approximate location of different available WiFi networks by using a combination of RSSI and SSID. Upon determination of the location (approximate) of the network AP, the coordinates will be logged and stored in NVM through the use of an on-board COTS GPS module. After a certain number of networks have been discovered (I haven't decided the threshold yet) the drone will return to base where the coordinates can be downloaded and plotted in a maps application.
Note: Obviously, this description is very high level. More details to come (i.e. HW, physical dimensions, etc.) in the near future.
zuul wrote 08/21/2014 at 04:54 point
hah nice
DubzTheGiant wrote 08/23/2014 at 21:49 point
Thanks!!
