GT2 Belt clamp design.
A project log for Simple DIY laser cutter
Basic laser cutter than can be made with standard shop tools.
philphil 04/08/2014 at 17:170 Comments
I finally got around to designing the belt clamps that will attach to the bottom of my X axis gantry plates.  This is a simple design and will only require 2 screws to keep the belts tight and in place.
I will be machining these out of HDPE.
