Become a member to follow this project and don't miss any updates
Homemade PCB-Mill / Laseretcher
Homemade X/Y-Table to mill PCBs and etch materials like leather with a Laser
16.1k 15 363 156
This project was created on 03/10/2014 and last updated a month ago.
Details
The finished project should mill PCB's and laser etch materials like leather. The goal for the workingarea is 400 mm * 400 mm at least.
Project logs
  • Big Update
    3 months ago • 0 comments
    Mounted the linear rails for the Z-axis:
    Mounted the Z-axis ballscrews:
    The entire system:
    The next step is to mount a big plate on the ballscrews and the linear shafts.
  • Another Test Video
    6 months ago • 0 comments
    This is the secont test-video, now with the small Z-Axis and a pen to plot.
  • Mounted the motors outside
    7 months ago • 0 comments
    Now the Motors for the X-Axis are mounted outside, so the Working-Area gets bigger.
View all 7 project logs
razorboy wrote 3 months ago null point
What kind of threaded rod/leadscrews are those? (From the picture where they are lashed together with cord). Where did you get them?
Are you sure? [yes] / [no]
Daniel Knueppe wrote 2 months ago null point
http://en.wikipedia.org/wiki/Ball_screw thats what you are looking for if you haven´t already found it yourself
uset182 wrote 5 months ago null point
Are you going to make tutorials videos how to make one ?
loldma wrote 6 months ago null point
Hi!
What type of motor did you use?
Where did you get the bars, plastic elements, etc?
ebrithil wrote 6 months ago null point
For motor, i used a standard NEMA 17 Stepper motor, the BArs are standart item aluminium Profile, and the plasticparts are 3D-Printed, when the Project is close to the end, i will make it Opensource.
tsiu wrote 6 months ago null point
Hey, what laser are you using or going to use? It looks like 445nm, but what optical power? And what about laser driver, are you going to use diy driver?
The 445nm laser was only a Test to see if my CNC drive the right way. Later im looking for a 1-2 W Infrared Laser and not with a diy driver.
geoper2 wrote 6 months ago null point
I wanted to ask why do you need 2 motors for the x axis instead of 1?
If i would only use 1 Motor, then the linear shafts of the Y-Axis wouldt have exactly 90° to the X Axis shafts.
Lerche wrote 7 months ago null point
Are you going to make the 3D files for the plastic open source?
This is a very interesting concept, as I am actually in need on a simple XY table.
ebrithil wrote 7 months ago null point
Yes i will make the whole Project Opensource, but only at the time when i finished it. I have a full 3D-Model of the my CNC in SolidWorks, iI'm gonna publish it, but later.
Matthew Gingerich wrote 7 months ago null point
What kind of control electronics are you using? I built something similar, but I designed all my motor controllers from scratch, so they aren't really compatible with existing CNC software. I wondered if you had any advice on off-the-shelf controllers. Thanks!
Sure, for the Controling I'm just using the RAMPS Board from thr RepRap community and a Arduino. On it i run the Repetier Firmware. To upload Gcode i use Repetier Host, and to generate the Gcode i use CamBam. Hope i could help you.
shlonkin wrote 8 months ago null point
Looks nice. Is the left motor for the Y-axis? If so, how are you moving the Y-axis? Are you using something like the coreXY mechanism (http://corexy.com/theory.html)?
ebrithil wrote 8 months ago null point
The left and the right motor is to move the X axis. the Y axis isn't installed yet only their linear shafts. On these two i will mount another sledge, where the Dremel or Laser is gonna be mounted. I will post a Statusupdate, but not know because the belts dind't arrived at the moment.
Similar projects
