Become a member to follow this project and don't miss any updates
OSCAR: The Open Screen Adapter
A super high resolution 9.7" LCD panel with an Arduino compatible adapter that connects to your computer
This project was created on 03/10/2014 and last updated 3 months ago.
Description
OSCAR is an adapter that allows you to connect a super high resolution 9.7” screen, often found in tablets, to your computer. It comes pre-connected to the LCD panel ready to be attached and is compatible will all operating systems using a Thunderbolt or DisplayPort connection. The board is Arduino compatible which makes modifying the behaviour easy and all the software and hardware is open source. The particular display used with OSCAR is the one most commonly found in the iPad 3 and 4, marketed as the 'Retina Display' and has a whopping 2048x1536 pixels. This gives it an amazing pixel density of 264ppi (pixels per inch) and glorious colours. The case we have designed for it in laser cut clear acrylic also enhances the wonderful looking display by putting it in an equally clean looking surround.
https://www.kickstarter.com/projects/1859884318/oscar-the-open-screen-adapter
Details
Connects to your computer using DisplayPort/Thunderbolt
Takes 12V 1A input (9-12V recommended)
Consumes a nominal 6W
ATmega32u4 microcontroller
TPS61176 backlight drivers
LMZ12001 high efficiency buck regulator
All spare IO pins available on 0.1" pitch headers. This includes 6 analogue pins, 9 digital, I2C, SPI, serial and 5V power
RGB LED for OSCAR status
Components
  • 1 × LMZ12001 TI SimpleSwitcher power module
  • 1 × TPS61176 Constant current LED driver
  • 1 × ATMega32u4 Microprocessors
Project logs
  • General public sale
    3 months ago • 0 comments
    We have recently opened an online shop for people who missed the Kickstarter and want an OSCAR.
    See www.oscaradapter.co.uk for more information
  • Production boards and file release
    8 months ago • 0 comments
    There have been a few delays with the production PCB-As but we have finally got the majority of the batch back. We have also released all of our files on GitHub which can be seen here: https://github.com/OSCARAdapter
    Once we have tested, assembled and shipped all the Kickstarter orders, we will be openeing orders up to the general public as we have had a few requests for boards after the Kickstarter ended.
    Production boards
  • Laser cutters are cool!
    a year ago • 0 comments
    One of the big perks of being at Uni, you get to use lots of very expensive equipment!
    Acrylic engraved OSCAR logos fresh off an Epilog Mini24 :)
View all 4 project logs
Jasmine wrote 7 months ago point
Hello Freddie, now is the time to add a few more details to your project to give it the best chance of going through to the next round of The Hackaday Prize.
By August 20th you must have the following:
- A video. It should be less than 2 minutes long describing your project. Put it on YouTube (or Youku), and add a link to it on your project page. This is done by editing your project (edit link is at the top of your project page) and adding it as an "External Link"
- At least 4 Project Logs
- A system design document
- Links to code repositories, and remember to mention any licenses or permissions needed for your project. For example, if you are using software libraries you need to document that information.
You should also try to highlight how your project is 'Connected' and 'Open' in the details and video.
There are a couple of tutorial video's with more info here: http://hackaday.com/2014/07/26/4-minutes-to-entry/
Good luck!
Are you sure? [yes] / [no]
Adam Fabio wrote 9 months ago point
Isn't it great when commodity electronics items reduce the price for us tinkerers? Thanks for submitting the OSCAR to The Hackaday Prize. Eventually we'll all have Google Glass brain implants, but for now, I'll settle for a retina display
Meli_Saelzer wrote 9 months ago point
Does this work for the ipad mini 2 retina display?
Freddie Temperton wrote 9 months ago point
Unfortunately not at this time
coolmail.2002 wrote 10 months ago point
i want to buy it :-)
Decase73 wrote 10 months ago point
So, it's a second monitor? I don't get it...
raznemonade wrote a year ago point
Will you maybe made that thing for the ipad mini retina display with touch functionality?
lucas.vanbeneden wrote a year ago point
Is this project available for purchasing?
Freddie Temperton wrote a year ago point
Just on the Kickstarter linked above
Similar projects
