Solar nanofluid power & water desalination
A simple solar power & water desalination apparatus utilizing nano fluids for improved performance and efficiency
This project will attempt to construct a solar device which will provide steam for cheap power generation as well as desalinate water with the aid of nanofluids. Focus will be made on exploiting low cost materials which will allow easier construction by the third world. An simple and repeatable nanoparticle synthesis process will also be provided.
David wrote 09/19/2023 at 11:12 point
Is this still active?
PointyOintment wrote 06/08/2015 at 18:36 point
Nanofluids?
