FASTWireless PWM
A Bluetooth radio transmitter/receiver that is a drop-in replacement for PWM cables.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
PWM Cables can be subject to signal interference, can break easily and are difficult to trace. They can also be cumbersome when you have moving mechanisms with actuators. At FAST Robotics we are building a Bluetooth Low Energy Transmitter/Receiver that is a direct replacement for PWM cables, easy to operate and multiple Transmitter nodes can be placed next to each other on standard .1" (2.54mm) header spacing.
