Become a member to follow this project and don't miss any updates
Breakout board set
This is set of small breakout board I use to fill up space on multipanel boards
This project was created on 03/18/2014 and last updated a year ago.
Description
When ordering bigger multipanel boards, I often have unused space on those. I decided to make set of small breakout boards to fill up corners of those boards with something useful.
Yes, one can buy those breakout board cheaply from china, but using wasted board real estate is for free.
Mike Szczys wrote a year ago point
Actually, you can easily embed your photos in the project description, logs, or instructions. The main project photo album is the only place that has a limit.
Are you sure? [yes] / [no]
jaromir.sukuba wrote a year ago point
This was my first project here on HaD projects. In the meantime I figured it out (ahem, actaully, I read that manual, everyone should do that at first place, you know). Thank you anyway.
Similar projects
