Authentic Blueprints
Back to overview
You know, the kind that are actually blue.
Craig Ciccone wrote 07/01/2020 at 15:54 point
Do you have a recommendation for when joining together multiple standard letter size transparency to make a larger negative? I have a 12 page print i'm doing for a large form blueprint with your method, but i fear using scotch tape might effect the UV process
Mindy wrote 08/22/2016 at 19:53 point
Also, to get that really prussian blue POP from cyanotypes, you can put about a capful of hydrogen peroxide (the kind you get from the pharmacy or supermarket is fine) in with the rinse water.
