Become a member to follow this project and don't miss any updates
Cyberpaul
A Les Paul style guitar with a dystopian cyberpunk aesthetic.
This project was created on 03/19/2014 and last updated a year ago.
Description
Decided to refinish an old guitar of mine, and somehow it turned into a futuristic cyberpunk oddity.
It's a perfectly functional guitar, refretted, restored and set up, which just happens to have a working fan with backlight.
Details
Uses a passive pickup system but with a few twists. Toggle switches select the bridge or neck pickup and add one of two (or none) capacitors in parallel to change the resonant frequency. Also decided on a simple mute switch in lieu of a volume control.
The external battery powers the fan and light, controlled by the red push buttons.
I've also rounded the back after removing the initial finish (nitro burns nicely), with a dremel, sandpaper and tons of elbow grease.
Components
  • 1 × Communist Bloc era guitar
  • 1 × Fender fret wire
  • 1 × Epiphone humbucker
  • 1 × VU meter
  • 1 × Assorted HDD parts
  • 1 × Cooler fan
  • 1 × Washing machine motor bits
  • 1 × Metallic gray paint
  • 1 × Natural shadow acrylic paint for weathering
Project logs
View all 4 project logs
Didi_Hack wrote 6 months ago point
Very cool Idee!!!!!
Are you sure? [yes] / [no]
Sam Novak wrote 8 months ago point
Very nice project, I love the saddles! What pickup are you using on the neck? It looks a little too fat to be anything I recognize and is it using a set-neck construction?
FiveseveN wrote 7 months ago point
Yup, set neck, which is rare for this kind of Soviet knockoff. The single-coil comes from another guitar of that era, and being the overwound single magnet type offers some hints of P-90.
Mike Szczys wrote 10 months ago point
Wow, that really turned out great! The up-close shots are stunning... the audience won't know what they're missing from afar. Thanks for showing off your work!
FiveseveN wrote 10 months ago point
I appreciate it! And I've already started work on the next one.
shlonkin wrote 11 months ago point
This is an awesome guitar. Does it have a connection to any sci-fi universe, or is it just a cool style?
FiveseveN wrote 11 months ago point
Didn't have a particular Universe in mind, just tried to fit together what I had on hand in a general decayed sci-fi theme. Inspired by the films I grew up with.
Eric Evenchick wrote 11 months ago point
That thing looks awesome. My audio stopped working suddenly, so I'll just assume it also sounds awesome.
Thanks! I'm gonna try to take some more pictures as soon as I find a proper entourage.
Similar projects
