BBQ Smoker Temp Control
temperature controlled fan/blower system to keep constant smoker temp.
Using a Teensy LC as the brains of this auto temp control unit. Set desired temp using LCD and buttons then unit will auto turn on blower/ intake fan to control smoker temp.
Hardware gathering phase
  • 1 × 2 channel relay
  • 1 × teensyLC
  • 1 × 100 ohm thermistor i have some 100 ohm thermistor probes that i found.
