Texas Ranger ROVER
WiFi and HTML/AJAX/COMET operated vehicle
Texas ranger is a differential traction vehicle made from wood pieces and plastic toy wheels.
It has a 2-degree-of-freedom turret mounted on top, that holds an ip camera, a laser pointer and, two PVC automatic cannons, made with two cheap gun toys mounted backwards and drived by two MOSFET. Turrent is 1-degree-of-freedom self-compensated inclination, measured by Wii nunchuck.
The vehicle is operated with a Linksys WRT54G, OpenWRT loaded. The router is connected via ethernet to the IP Camera and via serie to a home made board with two 16F876 PICs. The board controls motors for differential traction, Wii nunchuck reading and turret self-compensation is calculated on PIC and notified to router via RS232.
Laser ponter is used to project the dot in landscape, in order to estimate the distance to targeted object, via triangulation. A C program, executed in the router, downloads every frame from ip camera, decompress the JPEG stream using libjpeg, and finds the most brighness dot
Laser ponter is used to project the dot in landscape, in order to estimate the distance to targeted object, via triangulation. A C program, executed in the router, downloads every frame from ip camera, decompress the JPEG stream using libjpeg, and finds the most brighness dot inside a pre-defined region of the image.
Assuming that this is the laser dot, and calculating the amount of pixels from the dot to the image border, estimating the real distance to target, and showing it in the web page.
Remote control works as an another URL of the router web configuration. User send commands as the same way as he would play Quake or CS, by 'w', 'a', 's', 'd' keystrokes, and mouse movements and click for turrent movement, canon shooting and distance measurement.
View all 4 project logs
