Testing the inrush current the quick & dirty way
A project log for Mooltipass Offline Password Keeper
Offline password keeper project created by and for the Hackaday community
mathieu-stephanMathieu Stephan 06/24/2014 at 16:380 Comments
I'm guessing that very few of you know that USB certifications impose a very strict limit on a USB connected device's inrush current.
What's the inrush current?
It is basically the current that a device receives when it is connected to a USB port. It is usually high given the numerous decoupling capacitors on a board.
How to measure it?
One of the solutions is to do like I did: put a shunt resistor between your device and power supply, measure the voltage across it. As I'm sure you already know, it will represent the current going through it.
What should I see above?
This is the voltage across the shunt resistor when the device is first plugged to my computer. The USB certification specifies a maximum 50uC charge (Q = I*dt integrated) when the current is above 100mA.
Looking at the oscilloscope you can see a 500mV vertical axis, corresponding to I = V / R = 500/1.5 = 333mA. The horizontal axis is 20us.
What we are going to do simply count the number of "blocks" for given time bins (red zone). Let's say we have 5 time bins here:
- first time bin has 4 blocks (1.333A)
- second has 3 blocks (1A)
- third has 2 (0.666A)
- 4th and 5th have 1 (0.333A)
Yes, this is a very approximate measurement ;). Anyway, this gives us: (1.33+1+0.66+0.33+0.33)*20us = 53uC!
This is therefore very close to the norm.... we should reduce one of our capacitors' value then!
