Become a member to follow this project and don't miss any updates
Raspberry Eye
Head-mounted computer with see-through display made from cheap or printed components
This project is in this list
Browse all lists »
This project was created on 04/19/2014 and last updated 7 months ago.
Description
I wanted to do something interesting with my RPi and a 2.4" TFT LCD. Google Glass was hot in the news, so I've decided to hack something similar. The semi-transparent mirror was extracted from Eye of Horus Beamsplitter, and the projection lens is cut from a plastic 3x Fresnel magnifying lens. The box and mounting parts are 3D-printed from ABS. Head strap is for GoPro. One RPi USB port is used for WiFi, and second for 2.4Ghz small wireless keyboard/mouse combo. All together cost around 100$. I haven't figured out a good option for the power supply yet, and don't know if this thing can have a practical application. The display driver is fbtft framebuffer, so both text and (non-accelerated) graphical modes are possible, but with 320x240 resolution using X is not too exciting. Display brightness is sufficient if ambient light is not too bright.
Here is a demo video: https://www.youtube.com/watch?v=lCYnIHqwIJU
Details
A drawing of the mounting assembly: https://dl.dropboxusercontent.com/u/105504669/rpi_eye.pdf
My copy of notro/fbtft driver with modifications to product the mirror image: https://github.com/genericsoma/fbtft/tree/mirror (there only fb_s6d1121.c is modified, but it should be easy to duplicate for other controllers).
I've bought the beamsplitter here: http://amzn.com/B000NSMODK
The screen is ITDB02-2.4E from ITead Studio
The framebuffer driver for Raspbian is here: https://github.com/notro/fbtft (my version is slightly modified to produce a mirror image)
For the lens look for a "credit card size 3x fresnel magnifying glass"
Components
  • 1 × Raspberry Pi board Mine is 1st Gen B board
  • 1 × 2.4" LCD display I've bought mine from ITead Studio, other sellers have them too
  • 1 × Semi-transparent mirror Not easy to find, the one from Eye of Horus beamsplitter is unfortunately low-quality plastic
  • 1 × Fresnel lens At least 3x
  • 1 × GoPro head strap
  • 1 × IPazzport Mini Wireless keyboard Or similar (check for compatibility with the RPi)
  • 1 × Box, mirror mount 3D printed
  • 1 × Raspberry Pi camera board Connectors and Accessories / Power Entry Modules, Plugs and Sockets
Project logs
  • Raspberry Eye grows an eye
    7 months ago • 0 comments
    Played with RPi Camera Board recently to see if it can be used for simple image-recognition.
    Here is the result:
    This is produced by this python script using picamera module to capture the image, ZBar bar code reader to find qr-codes and pygame was used to draw stuff. Latency is around 1 sec using 1024x768 image size.
    I've realized there exists a problem with using see-through augmented-reality displays: if you need to draw something over a real object, you need to account for the camera offset from the display, which is important for close distances. I don't know how to calculate the correction dynamically without some kind of distance-detection hardware (the best would be to use a depth-sense camera... maybe they need to make one which is RPi-compatible).
    I'll try to make a small demo video soon.
  • Added "mirror" branch on github
    8 months ago • 0 comments
    I've added the code to produce the mirror image to "mirror" branch: https://github.com/genericsoma/fbtft/tree/mirror
    It applies only to S6D1121 controler (fb_s6d1121.c). If should be easy to use the same trick with similar controllers such as ILI9325. Basically the starting address is calculated differently and the so-called GRAM direction is set to the opposite.
  • Uploaded demo video
    9 months ago • 0 comments
View all 4 project logs
stopsendingmejunk wrote 7 days ago null point
Very cool. Would it be possible to move some of the bulkier components to a belt clip or something?
Are you sure? [yes] / [no]
JnC.Enterprises wrote 10 days ago null point
Great
CyberGateKeeper wrote 25 days ago null point
Wow, amazing! the applications are endless, i would love to collaborate a bit on this and get a version of my own built soon!
hamzageek wrote 4 months ago null point
looks Super Cool
genericsoma wrote 4 months ago null point
Mis012 wrote 6 months ago null point
what about using two cameras above each eye? It will be like 3d camera, or not? Or maybe something to get position of your finger, so you can manipulate with virtual objects?
I'm intrested in this, I'll make my own soon.
Rpi can only support one camera, AFAIK, and probably has not enough processing power for real-time manipulation.
Mis012 wrote 3 months ago null point
I think that I've seen a tutorial about adding more cameras, but you can always use USB cannot you?
flaco wrote 7 months ago null point
Hello, awesome project here !
Have you thought about replacing the screen, miror + lens(?) by an OLED screen? :)
Yes, only there were no cheap screens compatible with Rpi. Now I hope TinyScreen will be available next year.
surperdearm wrote 8 months ago null point
Do you want to sale one to me?
You can make one by yourself as well; that's the point of this community, I think.
KBart1960 wrote 8 months ago null point
Cool and interesting project.
The link is unfortunately down!
genericsoma wrote 8 months ago null point
the drawing link is fixed now
snapgamesza wrote 8 months ago null point
Really exciting project! Congratulations. Is the fbtft code on your github the version that produces a mirrored image?
Not yet, I will put it shortly, but it works only with this specific display, because I've used the scan direction parameter.
I've added the code to produce the mirror image to "mirror" branch (see the link in the project details).
botmayank wrote 9 months ago null point
Really great stuff!! Now how about some cool DBZ Scouter graphics :D
mik3britt wrote 9 months ago null point
So cool man! Great work!
fsf wrote 9 months ago -1 point
Hi,
I am brand new to your system and it keeps kicking me out or giving me errors....BUT it could very well be me as well. I have an age old challenge for you science buffs as you are obviously smarter than this 66 year old guy, as you have done it with plastic. We have found the way to remove the black sand but Is there any new and innovative way to seperate just plain old sand from gold dust other than plain old panning.
Thanks
God Bless
Freddy ...I would love to hear..!!
james.dellow wrote 9 months ago 2 points
@genericsoma- would love to use this with the young people I work with. Could we chat about best ways to approach this project- my email is james.dellow@thesquad.org.uk
prostheticknowledge wrote 9 months ago 2 points
@genericsoma - Is there a video demonstration of this?
genericsoma wrote 9 months ago null point
I'm in the process of making one. Will be ready soon.
woundedkarma wrote 9 months ago null point
Very cool :) I play with the idea in my head a lot.. I wasn't sure how to do the display. Granted I tend to avoid "spoilers" or I might have seen this somewhere else. I will have to keep an eye out for that board game :> Maybe it will show up in a thrift shop.
Isn't there any way to get the raspberry pi off of your head and into a pocket or carrying case?
For a battery pack, I'm going to try this: http://amzn.com/B009V5X1CE with my first project.
This pack seems pretty good deal :) The beamsplitter is actually an optional item: http://amzn.com/B000NSMODK
danielmcgraw wrote 7 months ago null point
Hi woundedkarma,
Myself and Mike have been working on a project to do this.
Please see here: http://hackaday.io/project/1368-Raspberry-Pi-Smart-Glass
Dan
Lutan wrote 9 months ago null point
This project looks awesome, I love it. Too bad I will use my Raspberry Pi for a custom PirateBox, I also already killed my tech budget for the next months. Is the whole thing easy and comfortable to wear?
It's not too bad, but I didn't try to wear it for hours.
davedarko wrote 9 months ago null point
Any chance you can share some sketches or files for for this?
Is SolidWorks format OK?
A theoretical sketch, like a drawing of the insides would be fine, since I just need to get a clue about the basics. I'm only able to afford to work with free 3D suits, so handling solidworks format could be a problem? I think I have to buy some stuff and try around a bit ;)
I'll put some sketches and STL files soon.
Tyler Anderson wrote 9 months ago null point
I've always wanted to put something like this in my car. What is the focal distance of the projected image? That is, how far in front of you does it appear to be.
About 30cm with the current setup. It's possible to have the image "at infinity" by increasing the distance from the screen to the lens a little (to about 7cm).
Similar projects
616 2 15 5
Project Owner Contributor
Raspberry SPY NoIR
by chiprobot
