Added "mirror" branch on github
A project log for Raspberry Eye
Head-mounted computer with see-through display made from cheap or printed components
genericsomagenericsoma 05/28/2014 at 23:120 Comments
I've added the code to produce the mirror image to "mirror" branch: https://github.com/genericsoma/fbtft/tree/mirror
It applies only to S6D1121 controler (fb_s6d1121.c). If should be easy to use the same trick with similar controllers such as ILI9325. Basically the starting address is calculated differently and the so-called GRAM direction is set to the opposite.
