MoVI - Makita Battery Power Pack
Use 14.4v Lithium Ion batteries to power a Red Camera and accessories on a MoVI camera stabilization gimbal.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 2
Eric Evenchick wrote 04/30/2014 at 04:58 point
Looks like a cheap way to get some rechargeable, replaceable batteries. Did you have to build custom circuitry to do voltage conversion, or can the camera charge straight from the batteries? Also, are those off the shelf voltage monitors?
robin wrote 05/31/2014 at 17:08 point
Hey, there is no voltage conversion as makita makes a 14.4v battery that is common to the camera industry. I would love to make a voltage regulator to be able to use 18v batteries in the future. Yes, these are off the shelf voltage monitors, the Chinese variety. There is circuitry to prevent reverse bias to each battery and fuses etc...
