Become a member to follow this project and don't miss any updates
$300 Pick and Place / 3D printer
An affordable electronics manufacturing system for hobbyists, students, & small businesses. Inspired by RepRap. Powered by OpenPnP/FirePick.
55 801 583
Share on twitter   Share on Facebook
This project was created on 04/29/2014 and last updated 24 days ago.
Description
FirePick Delta is an open-source electronics manufacturing system, inspired by RepRap and powered by OpenPnP and FirePick's own Computer Vision software. We are taking the beginning steps towards a smart appliance that can manufacture electronic circuit boards in a home or office environment. Our machine is able to assemble open-source hardware boards like Arduino and Raspberry Pi accessories, and also has the capability to 3D print. It features an auto-tool changer that allows multiple plastic extruders, and/or multiple SMT vacuum nozzles. Other tools and applications will be available as our product matures.
We will be launching a Kickstarter campaign once we have a working prototype.
Details
In order for this project to be successful, we must define a set of criteria, and then break the problem down into a set of little problems that can be tackled, one by one.
CONSTRUCTION
We chose a Delta robot configuration over a more conventional Cartesian design.  This allows us more speed, less BOM cost going bearings and linear slides, and easier build / configuration.  This will be covered in more detail in a future post.
I've taken the RepRap philosophy to heart.  There are no swiss-machined parts and crazy Japanese bearings in this machine.  I've spent weeks pulling my hair out trying to figure out the cheapest way to build  a PnP machine without sacrificing quality.  The original RepRaps used 608 bearings and LM8UU linear bearings because they're the cheapest, most-available type out there.  They built their machines around these parts, rather than designing the machine first, only to be pigeon-holed into a weird bearing size.  The best part is that the popularity of the RepRap movement has brought down the prices of these parts even further.
I've designed FirePick Delta around the following parts:
ACCURACY AND SPEED
SMT parts are getting smaller and smaller every year.  If we made a crappy machine, it would be outdated by the time we'd finish it.  We've taken the proactive approach, and created a set of simulations that test various configurations for accuracy and speed, that uses monte-carlo trials and evolutionary algorithms to "find" a correct delta geometry that fits our needs.  We are attempting a design that *should* be able to place 0201 components!  Although we'll be happy if it places 0402's and QFN's.  I'll be talking more about this in a future post.
OPEN SOURCE vs. CLOSED SOURCE
We will keep it open and pay it forward. This gives us the ability to leverage the following Open Source projects in our design:
  • OpenPnP - Is a project to create the plans, prototype and software for a completely Open Source SMT pick and place machine that anyone can afford.
  • FireSight - A high-level computer vision framework designed for Pick and Place machines, powered by OpenCV. No programming experience required - A pipeline of image operations is specified with a JSON structure. The results of the operations are returned as a JSON structure.
  • FireFUSE - FireFuse is the FUSE driver for all FirePick machines. FireFuse maps all hardware input/output functions for FirePick to individual files in the /dev/firefuse virtual file system. For example, the current camera view of the FirePick camera is presented as /dev/firefuse/cam.jpg. Presenting the camera output this way simplifies and generalizes access to the camera, since "it's just a file."
  • FireBOM - Similar to ThingDoc, FireBOM will auto-generate BOMs, documentation, real-time pricing and distributerer info, and keeps track of approved vendors and SMT part footprints.
  • FireMOTE - A web-based frontend for OpenPnP.
  • FireREST - FireREST is an open-source REST protocol for automated manufacturing. With FireREST, you can connect smart camera...
Components
  • 1 × Raspberry Pi Model B Soon-to-be replaced with the Raspberry Pi Compute Module!
  • 1 × Raspberry Pi camera Used by OpenPnp / FireSight / OpenCV
  • 1 × Arduino-compatible motion controller board Runs modified RepRap Marlin firmware
  • 1 × FirePick Delta frame Misumi HFS5 20mm aluminum extrusion, 300mm x 300mm base
  • 3 × FirePick Delta Motor Drive Assembly NEMA 17 stepper with custom printed GT2 belt reduction and delta arms
  • 6 × Delta rod end links, ~270mm Carbon fiber rods with Traxxas 5347 ball links
  • 1 × Delta Pick and Place Head With custom Auto-Tool Changer mechanism
  • 1 × PCB Tray
  • 11 × Component Tape Feeders Holds up to 11 SMT feeders that each hold up to 4 parts each. 3D printed from ESD-safe conductive ABS plastic.
  • 1 × Power Supply Standard ATX 400W power supply
Project logs
  • FirePick Delta System Design Document and Youtube Video
    a month ago • 0 comments
    Here's our Introductory Youtube video for the Hackaday Contest, Stage 1 & 2, as per the Official Rules:
    Here's our System-Level diagram (still a work in progress):
    Admittedly the system diagram is very busy, but it does accurately reflect our desired system configuration.  I will try to explain the various parts of the diagram and how they work together.
  • Upcoming Events
    2 months ago • 2 comments
    Orlando Maker Faire 2014
    September 13-14, 2014
    Orlando Science Center
    See you there!
    New York World Maker Faire 2014
    We got accepted! We'll be in New York on September 20 & 21, 2014!
    New York Hall Of Science
    147-01 111th Street
    Queens, NY 11368
    OSCon 2014
    OSCON 2014
    It's official, FirePick Delta (aka the $300 Pick and Place / 3D printer) will be at the OSCon Open Hardware Showcase!
    Who:
    Neil Jansen on behalf of the FirePick team. Anyone at all interested in seeing FPD, that live around the Portland area, that can make it is invited to come. I believe the expo hall admission is $25.
    What:
    FirePick Delta @ OSCon Hardware Showcase
    Where:
    Oregon Convention Center, in Portland, Oregon
    http://www.oscon.com/oscon2014/public/cfp/336
    When:
    July 22-23, 2014
    Why:
    Because Open Source! Because hacking!
  • 7/12/2014 - Let's Take a Selfie!
    2 months ago • 1 comment
    Robots need to take selfies too!
    In this post, I'll explain the importance of up-looking vision, and how we cheat with a mirror to accomplish this. I'll also cover the state of our computer vision system and where we're going from here.
    In the picture above, you can see a Raspberry Pi camera, looking at itself in a mirror, in order to see the nozzle, and and parts that might be hanging around there.  We can use computer vision to calculate and adjust the part offset and rotation, to make up for the fact that it's impossible for us to pick a part from a component feeder with enough precision.  We can also use computer vision to calculate the offset of the nozzle to the camera, not only at zero degrees rotation of the nozzle, but also for other rotations, which means we can calibrate out the wobble of the cheap Luer lock syringe tip that we use.
View all 8 project logs
Dashack wrote 17 days ago null point
You will create a revolution under 300.00 .ultimately we(self start hackers, cottage industrialists ) want a turn key system at our homes / workbenches. This is a critical link in that chain . The hack space will open out and we will start seeing long term a super explosion of innovation. Great work .
Are you sure? [yes] / [no]
Jasmine wrote a month ago null point
Hello Neil, Your video looks good, and you've got more than 4 project logs. I couldn't see your system design doc. Maybe you can highlight it in your details? Overall your documentation is great, and we're really pleased you entered. Get in touch if you have any questions.
Neil Jansen wrote a month ago null point
Hi, I've been out of town the last few weeks, but I'm back and will get the system design document done this week hopefully. We've been working on a moving target, so we've left this step off until the last possible minute :) As far as documentation goes, we still have a lot of stuff to add (I'd consider everything up now as more of an introduction to the project). We plan on adding a considerable amount of information to what we have in the forthcoming weeks / months.
Great stuff. Get as much as you can up before the 20th of August as that's when we will review it for the next round.
Jasmine, I added the system design document at: https://hackaday.io/project/963/log/7557-firepick-delta-system-design-document-and-youtube-video
If you can take a look before the deadline, that would be great. Thanks!
spackl3r wrote 2 months ago null point
Can't wait to see it work (not to mention a kickstarter campain :)
"Shut up and take my money" meme on standby...
Michael Sampson wrote 2 months ago null point
Guys this is awesome... It really is. Where do i sign up to buy one!!!!!!!
Neil Jansen wrote 2 months ago null point
You can sign up here: http://delta.firepick.org/developers/
Andrew wrote 2 months ago null point
I'd really like to see this come together. Especially the vision part of it.
We have a Madell Technologies Pick & Place machine here in lab, and it's vision system is pretty piss-poor, leaving a machine that can't really do it's intended job of finding and placing parts. Not to mention all the rest of the crummy parts software.
So, I'm anxiously awaiting the release of the mechanical CAD files! I'll add another nag onto the pile for those.
Neil Jansen wrote 2 months ago 1 point
CAD files will start to go up tonight! And the rest will follow thereafter. we've got several repo's, it will be going in the github.com/firepick-delta/firepick-delta repo.
We feel you on the Madell Technologies stuff, they're so bad I'm surprised they're still around. We hope to put 'em out of business, or force them to improve their quality ;)
Github mechanical files are up!! I'm still getting them all added, but it's a start. https://github.com/firepick-delta/firepick-delta/tree/dev/mechanical
Boz wrote 2 months ago null point
Awesome! Gets my vote if it works
Especially love the idea of a optional solder paste dispenser to complete the package.
Doing solder paste by hand is messy and time consuming and requires a real steady hand, and having a good template made is so expensive.
Minimum Effective Dose wrote 2 months ago null point
The first time I paid for a steel solder stencil was also the last time. Rough-cut edges, and the "solder paste squeegee" included in the $20 accessory add-on was a scrap piece of steel with tape on the sharp edges. F that.
Now I laser cut them out of Mylar (which is a trade name of DuPont, look for "Dura-lar" at art supply / drafting supply stores.) Much faster, and literally 200 times cheaper.
Pixel Pirate wrote 2 months ago null point
So... can it place BGA packages? *shifts eyes left and right*
Yes, we are designing it in such a way that it should be able to place BGA packages, and have computer vision to make up for various tolerances in placement and rotation. But we're still verifying how accurate we can actually place. We'll be ordering a few BGA test kits from Topline, that include dummy BGA's and PCB's that are wired in daisy-chain pattern through each pin. That will let us know if we can do it consistently, without breaking the bank buying expensive BGA's and writing verification tests.
D1plo1d wrote 3 months ago null point
Greetings from RetroPopulator, the new team on the open source pick and place block!
Check it out, our RetroPopulator's already done it's first successful pick and place demonstration: http://hackaday.io/project/1605/log/4353-retro-populator-in-action
*And* that was all done from a .brd file automatically parsed by our PopCAM software!
Ok, so it's time for some friendly competition. The ball's in your court now and all that. Can't wait to see your demo! :)
Juha Kuusama wrote 3 months ago null point
Greetings from LitePlacer, the third pick and place project in the competition, too! My project is at http://hackaday.io/project/1755-LitePlacer---a-low-cost-Pick-and-Place-machine
May the best picker-placer win!
Neil Jansen wrote 3 months ago null point
Great, we love competition! Don't get too comfortable, although we've been quiet the last few weeks, we've got some really cool stuff in store. We've got working vision, AND rotation! Not to mention a bunch of other cool stuff.
Btw, the only thing we love more than competition is collaboration! Don'tn be afraid to get in contact with us if you would like to work towards standard feeders or vision software, or anything else.
D1plo1d wrote 2 months ago null point
For sure! We've got a lot of basic testing left to do but I think once we've got reliability and setup sorted out a bit more we should start looking at how the two projects can cross-pollinate.
PS. Check it out, we just pick and placed 2 boards in one run at full speed: http://hackaday.io/project/1605/log/4715
Blecky wrote 2 months ago null point
Cheeky :P
Keep it up guys, a little feather ruffling makes for an interesting competition.
Krinkleneck wrote 3 months ago 1 point
Call me crazy, but if the designs are mainly 1 sided pcbs then you could make it have a heated bed. That way you can place and solder in one machine maybe? Or, you could have the machine move the boards directly into an oven to reflow. You could connect boards to a conveyor system that starts with blank pcbs, they go under a roller with the pcb pattern, through a slow etching bath, through a preset robotic QC for connectors, into a tinning solution, under a soldermask roller, under a masked uv source, cleaned, More QC to make sure the connectors aren't covered, through a pasting station, in and out of the placement, through an oven, colling station and one final qc to make sure everything is connected.
zakqwy wrote 3 months ago 1 point
Hi Neil,
I'd love to look through your CAD model in detail. What are your thoughts on putting all project files on a shared repo for folks to freely download and open? It seems like you've put a lot of time in to designing the linkages (amongst other parts) and I think we could all learn a lot (especially those of us that are new to kinematics).
Thanks!
Zach
My apologies for not having the 3D CAD files up by now. There are a few things we're working on to get them posted. #1 we're moving some of our repositories around to be a little more self-explanatory and easier to maintain. We've created a github 'org' and we are in the process of forking to the firepick org and deleting the old ones under Karl's firepick1 account. #2 we are trying to finish documentation and part numbering so that people know what they're building, and how many parts to print. #3, I'm putting under a yet-to-be-created Open Source license that I'll explain soon. Hope that's understandable. We have five teammates now, working full-time to get all of this stuff done. They should be posted very soon, I will let everyone know when they go live.
Robert_sl wrote 3 months ago 1 point
Requesting 3d files for the printable delta section :)
Hi, we'll have the files posted soon... We're trying to catch up on documentation and other stuff. I'll make a post when we have files available to download. Thanks for the interest!
Robert_sl wrote 3 months ago null point
I'm interested in building a reprap with the delta setup you currently have. How suitable do you think this design is in this respect? Have you tried printing with it and how is the accuracy and speed?
I did a bit more reading and it looks suitable to me.. see my new comment above :)
Kiltjim wrote 3 months ago null point
I've got something like 10 years in manufacturing on pick and place equipment, electronics, and coding (probably not much help here), but if I can lend a hand, I would certainly love to see this become a reality.
Eric Evenchick wrote 3 months ago null point
There's devices out there to print PCBs at home, but assembly is the really painful part at this point. Really looking forward to seeing this device progress, and glad that you've set some ambitious goals for the component sizes.
bremenpl wrote 3 months ago null point
Hi there i am really impressed by the work youve done. I work in a company that creates small factor pick and place machines. I am in RND departament taking care of the low level programming and hardware. I would surelly like to contribute to your work, it has hudge potencial.
josheeg wrote 3 months ago null point
I am interested in trying your computer vision setup what components of this design can be bought and tested for it? Rasbery Pi and Pi camera?
Yep, just a Raspberry Pi, the camera, and the FirePick1/Firesight github repository linked above (the documentation is in the github wiki).
dumi.gumede1 wrote 3 months ago null point
Printer*
dumi.gumede1 wrote 3 months ago 1 point
Doesn't the project has to be innovative ? Anyone can get a 3d ptriinter
You're right. Anyone can get a 3d ptriinter. We must not be innovative.
willyboi111 wrote 3 months ago null point
Please don't hate!! Also this is not a 3d printer! Very well documented and the Innovation IS THERE!!!!!!
Mike Szczys wrote 3 months ago null point
You have an amazing jump on documenting your work. I'm so glad you entered it in The Hackaday Prize.
Keep doing what you're doing!
Thanks :) I've just begun the documentation process.. There's so much stuff that I still need to post. Thank you guys for creating a reward system that motivates hackers to document the stuff they build.
egoodchild wrote 3 months ago null point
Hey awesome project. I noticed that you guys are looking for help on this project. I would like to help you guys make it a reality in any way I can, I to would like to see a sub $500 pick and place on the market that is easy to use.
I have a full electronics lab at my disposal at my house, with all of your standard lab equipment scope, sig gens, soldering, reflow. I will also soon have an 80W laser cutter, once I finish building it. I also have access to mills, high dollar 3D printers, epilog laser cutter and CNC mills.
I’m very adept at multilayer high speed and high power PCB layout, FPGAs, MCU, and other embedded hardware/software design.
Keep up the great work!
Thanks for reaching out, could you send an email to njansen1 at gmail.com? We're always looking for dedicated people to help.
mattf wrote 4 months ago null point
Very cool project. Maybe it is worth considering using a beagle bone black in place of the RPi? The BBB already can run linuxcnc, and has some realtime support so you could maybe remove the need for the arduino in the system. Also, I believe the BBB's processor is more powerful than the RPi, which may come in handy for openCV processing. Just a thought.
Neil Jansen wrote 4 months ago null point
We like the BBB a lot, and plan to support it (and other Linux SBC's) in the future. The three main reasons we're using the Raspberry Pi right now is 1) price, 2) availability, and 3) the camera is just amazing when unscrewed to macro focus. it's the perfect size and we have lots of manual control of exposure and other settings that other USB cams don't offer. Once we get over these hurdles, there will definitely be support for the BeagleBoneBlack in the future.
rudiahlers wrote 4 months ago null point
I would like to get involved in this project as well, but I am in South Africa. My skills include Arduino, solderings, some coding, and plenty hardware hacking!
Cool! Send me an email at njansen1 at gmail.com, and we'll talk there.
PointyOintment wrote 4 months ago null point
A year or two ago I saw a DIY feeder that used just a razorblade to separate the tape, and it seemed to work pretty well.
For motorized tape removal, why do you need a stepper motor? Wouldn't a DC motor with a torque limiter of some kind (slip clutch, or just insufficient power available) work fine?
Yes, a DC motor with torque limiter, either mechanical or electrical, would work great. We went with one specific approach for our prototype, which is a single stepper motor that drives up to twelve cover tapes, where each tape spool contains a clutch (actually a set screw with a nylon tip). This allows you to simply add another feeder, when you put it in the slot, it will automatically engage the drive shaft from the previous feeder. The stepper motor easily moves the shaft a fixed number of steps, regardless of whether there's one cover tape being used, or twelve (a DC motor's turns would vary with load and voltage). We feel that this is a pragmatic way to make a flexible system on the cheap. Estimated cost of 12 8mm tape slots (3 feeders) and the stepper motor drive is only about $25 to 40. That gives a total of 48 feeders per system for around $130.
KingOfKYA(Travis K. ) wrote 4 months ago null point
I will be watching this project:)
Hope you get it working
Lerche wrote 4 months ago 1 point
Neil, you state you need help. I am rather good with KiCAD and I am an expert in soldering tiny stuff (really, I do 0201 in hand), and I am overly interested in making my own pick and place machine, so why not help out? I do however live in Denmark, long from you, so maybe I can do something from here? Regards, Lerche
Sure! We've got quite a lot of stuff to work on, and would love to have your help. Send me an email at njansen1 at gmail.com.
Jasmine wrote 4 months ago null point
Great info. Would love to see updates about this, and also see what projects you print.
Thanks! I'm a bit behind on updates as I'm applying for the HAXLR8R hardware accelerator this week, but I'll hopefully have some stuff posted in the next few days. Maybe even a video of the machine working by the end of the week.
Good luck with HAXLR8R. A video would be great.
Not sure if you saw it already, but I posted the youtube video to the HAXLR8R video in the build log section above... let me know what you think!
zakqwy wrote 5 months ago 1 point
Interested in the "secret sauce". More info on this?
Neil Jansen wrote 5 months ago 2 points
Absolutely. I'm going to start posting bi-weekly build logs starting tomorrow, starting with a project introduction. From there I'll cover the feeder design, nozzle design, custom motion controller, and other pieces in detail.
