Display Board
A project log for D-DAQ
automotive parameter & performance monitor & logger
michael-obrienMichael O'Brien 05/31/2014 at 07:020 Comments
Initial design of the display board is done. Time to send it in to get fabricated. I'll look at the quote tomorrow morning. Outside rectangle is the glass boundary of the OLED screen. Inner is the viewing area.
The sides have 5 LEDs each: the two larger one are accent LEDs and there are much smaller warning lights above, between, and below those. Just realized that there is no way to have all lights remain off, as some may desire. I'll add in a 3-pin jumper to disable them before getting it fab'd.
In case you're wondering, I'm mounting the display upside down. I'll be using spare leads from through hole components as wire tie downs to secure the display at this time. The white strip is a slot where the cable will fit through with some clearance to prevent chaffing.
