Proto Version 4 Schematic Capture
A project log for D-DAQ
automotive parameter & performance monitor & logger
michael-obrienMichael O'Brien 07/23/2014 at 06:020 Comments
Finished this puppy up. Contrary to what I was initially planning, I am not revising the board design to incorporate an off-board power supply subsystem.. If needed that'll happen down the road though. I have though come across numerous little bugs that I was not aware of or overlooked previously. Moreover, I feel I've significantly improved the base design of D-DAQ. Anyhow, the changes are as such:
Changes/Corrections/Bug fixes:
This has taken the better part of 3 days' work to overhaul, double check, and research. The schematic capture is updated, but there is no board layout to go with it at this time. Because I have theoretically decent EMI filtering from 2 MHz and above on the analog ground and have personally 'discovered' feedthrough capacitors, I'm comfortable starting the sensor board layouts. I know I said I'd start them more than a month ago if memory serves, but now I have a fair amount on confidence that I know which devices and filters I can use for helping with noise immunity. That being said, I need to figure out band pass noise suppression techniques for some of these sensors.
