[M] Cooling ducts
A project log for Coaxial8or [gd0144]
Full-colour FFF? Multi-materials with unparalleled interlayer bond strength? Abrasives without abrasion?
kelvinakelvinA 05/13/2023 at 14:350 Comments
I've now modelled the cooling ducts. The airways themselves are not optimised at all, but it should serve as a good starting point.
I also did this to see if there was anything else I might need before I bought the AliExpress BOM, since I've found it unrecommendable to buy components before the assembly file has been completely modelled.
I'm planning to self-tap M5 screws into the 6028 fans. Here's what it looks like with the fans inside:
Hopefully, the plastic being 3mm away from the hotend is good enough for it to not melt.
