3D Printers Comparison
Creatbot 3D Printers | ![]() | ![]() | ![]() | ![]() | ![]() | ![]() | ![]() |
DX DX+ | DE DE+ | D600 | F160 | F430 | PEEK-300 | F1000 | |
Build Size (L*D*H) | 300*250*300 (520)mm | 400*300*300 (520)mm | 600*600*600mm | 160*160*200mm | 400*300*300mm | 300*300*400mm | 1000*1000*1000mm |
Shaft Structure | Cross Axis | Core XY | Gantry (Linear Module) | Core XY | Gantry (Linear Guides) | Gantry (Linear Guides) | Gantry (Linear Module) |
Filament Diameter | 1.75mm (3.0 optional) | 1.75mm (3.0 optional) | 1.75mm | 1.75mm | 1.75mm | 1.75mm | 1.75mm |
Extruder | Geared Remote | Geared Remote | Geared Direct Drive | Direct Drive | Direct Drive | Direct Drive | Geared Direct Drive |
Nozzles | Double (Max.3) | Double (Max.3) | Double | Single | Double | Double | Double |
Best Printing Speed | 45mm/s | 45mm/s | 45mm/s | 60mm/s | 55mm/s | 60mm/s | 60mm/s |
Resolution | 0.05mm | 0.05mm | 0.05mm | 0.04mm | 0.04mm | 0.04mm-0.4mm | 0.1mm |
Layer Resolution | 0.02mm | 0.05mm | 0.05mm | 0.01mm | 0.02mm | 0.05mm | 0.05mm |
Screen | Touch 4.3" | Touch 4.3" | Touch 4.3" | Touch 4.3" | Touch 4.3" | Touch 4.3" | Touch 9.7" |
Nozzle Temperature | Max. 260°C | Max. 260°C | 260°C+420°C | 260 (Max.420)°C | 260°C+420°C | Max. 500°C | 260 (Max.420)°C |
Hot Bed | Max. 100°C | Max. 100°C | Max. 100°C | Max. 150°C | Max. 140°C | Max. 200°C | Max. 100°C |
Hot Air System | - | - | Y (70°C) Pro | Y (70°C) Peek | Y (70°C) | Y (120°C) | Y (60°C) |
Filaments Drying | - | - | Y (45°C/65°C) Pro | - | - | Y (45°C/65°C) | Y (45°C/65°C) |
Air Filtration | - | - | Y | - | Y | Y | Y |
Emergency Stop | - | - | Y | - | - | Y | Y |
Servo Motor | - | - | X/Y | - | - | - | X/Y/Z |
Bed leveling | Manually | Manually | Automatic Pro | Manually | Automatic | Automatic | Automatic |
Storage Media | USB Disk | USB Disk | USB Disk | USB Disk | USB Disk | USB Disk | USB Disk |
Fully Enclosed | Half | Half | Full | Full | Full | Full | Full |
Max. Power | 300W | 360W | 1000W/4000W Pro | 340W | 1500W | 3000W | 4000W |
Input Voltage | 110V/220V | 110V/220V | 220V | 110V/220V | 110V/220V | 220V | 220V |
Packing Size | 550*500*670(870)mm | 720*560*670(870)mm | 1000*1030*1300mm | 470*420*600mm | 750*580*720mm | 650*600*750mm | 1910*1510*2205mm |
Packing Weight | 35(40)kg | 45(55)kg | 180kg | 25kg | 62kg | 100kg | 640kg |
Max. Nozzle Temperature | F160: 260 ℃ F160-PEEK: 420 ℃ |
Max. Bed Temperature | 150 ℃ |
Max. Chamber Temperature | 70 ℃ (F160-PEEK) |
Max. Nozzle Temperature | 420 ℃ |
Max. Bed Temperature | 140 ℃ |
Max. Chamber Temperature | 70 ℃ |
