I'm thinking about adding an extra ground pin to the board, next to F0/F1, for an external crystal. However, breakout board pins usually come in pairs, so one extra pin needs something to do. What would you add?
If you have them all broken out anyway, why not add another ground? looks like you have a VDD over there and it's always good to have them close to run it from a battery or anything with a pin header plug.
When I add a ground pin on the F0/F1 side (bottom left in the picture), the second ground would be on the other side where I already have a ground pin (top right in the picture). How about a voltage regulator input next to that?
1-wire ID pin.
Solve world hunger.
"Solve world hunger" pin! You forgot to call it a pin. Nobody knows you're talking about a pin now.
Then I'd have to make it a HAD prize entry - nope.
ah, I thought it would add another one between vdd and b1.. sry. Regin sounds good.
