Introduction to ESP32 Module
Hi Guys! Hope you’re well today. I welcome you on board. In this post today, I’ll walk you through the Introduction to ESP32 DevKitC Board. The ESP32 is an entry-level development board that belongs to the ESP32 series. This device comes with a rich peripheral set. You’ll get hassle-free prototyping with the built-in ESP32 Pinout..
- ESP32-DevKitC ( Produced by Espressif ) is an entry-level development module, used majorly in IoT cloud-based embedded projects.
- ESP32 module is an efficient quality board customized for scores of applications and is perfectly compatible with Arduino IDE.
- The I/O pins on board are installed as female pin headers on each side of the board. This provides easy and hassle-free interfacing.
- ESP32 features Bluetooth and WiFi functions, where the rich peripheral set is available for rapid prototyping.
- This tiny component comes with ready-made system requirements. All you need to do is plug this device using a USB cable and play with it on the fly.
- Boot-mode and Reset buttons are incorporated on board and it includes various ESP32 modules covering ESP32-SOLO series of modules, ESP32-ROVER series, and ESP32-WROOM series.
- USB micro connector and USB-UART Bridge, and LDO regulator are also included in the device.
- The ESP32 pinout allows the prototyping on a breadboard.
- The LDO output onboard is mainly used to power up the off-board additional electronics.
- The outputs of peripherals are joined together to provide easy prototyping.
ESP32 Projects & Applications
- Used in Network projects.
- Employed for beginner level DIY projects.
- Employed in the prototyping of IoT devices.
- Used in projects that require Multiple I/O interfaces.
- Used in low power battery-operated applications.
