Product features: support Beidou differential positioning and UWB positioning, automatic switching between indoor and outdoor high-precision positioning, positioning accuracy up to 2 cm outdoors, up to 10 cm indoor positioning accuracy, IP67 protection level, industrial-grade design.
Product parameter
Device model | HXZK-URT |
Charging voltage | DC5V/1A |
Indicators | 4, 1 RTK indicator, 1 power indicator, 1 4G signal indicator , 1 UWB indicator light |
Output power | -24dBmM/MHz |
Life time (UWB mode) | >2 months |
Life time (differential mode) | >10 hours |
Charging port | Magnetic charging |
battery | 3000mAh |
UWB working frequency band | 3.75-4.25GHz |
UWB refresh rate | 1-100HZ |
G refresh frequency | 1-20 HZ |
Satellite system | 北斗+GPS |
Differential accuracy | Plane accuracy:±(30 + 1×10-6×D) mm Elevation accuracy:±(50+ 1×10-6×D) mm |
Channel bandwidth | 500MHz |
UWB antenna | Built-in omnidirectional antenna |
GPS antenna | External spiral rod antenna |
UWB Location Algorithm | support TOF/TDOA/RTK |
UWB positioning accuracy | 10Cm (unobstructed) |
UWBCommunication distance | >300m |
Size | 57.5x85x59.5 |
weight / g | 300 |
Operating temperature | -20℃~65℃ |
Working humidity | 0%~90% No condensation |
Protection level | IP67 |
Dormant | Smart sleep |
ROHS | compatible |
SOS alarm | support |
Low battery warning | support |
Automatic sleep and wake | support |
Richard
