LM317
elena-smithElena Smith wrote 04/29/2021 at 12:54 • 2 min read • Like
LM317 is a positive voltage regulator with three different terminals Adjust, Vout, and Vin respectively. It can supply the output voltage in a range of 1.25-37V and a current of more than 1.5A. It has advanced line regulation and load regulation standards as compared to the general regulators. It has a lot of applications in real life e.g. motor controllers, power bank solutions, hydraulic valve, ethernet switch, battery chargers, etc.
Introduction to LM317, how to start using LM317, getting started with LM317, how to getting started with LM317, how to use LM317, LM317, LM317 proteus simulation, LM317 proteus, proteus LM317LM317 Working Principle
LM 317 works on a very simple principle. It is a variable voltage regulator i.e. supports different output voltage levels for a constant applied input voltage supply. A variable resistor is connected at its Adjustment (Adj) terminal in order to control the level of the output voltage according to the requirements of the circuit. In other words, we can say that LM 317 can step down the voltage from 12V to several different lower levels.
LM317 Pinout
LM317 Applications
LM 317 has a very wide range of applications, a few of which are given below.
                                             LM317 Pinout
Like
