​ SMART LCD DISPLAY MODULE FOR AUTOMATION
94754sakura94754sakura wrote 05/28/2021 at 05:05 • 3 min read • Like
For the industrial automation customers, STONE intelligent TFT LCD module is also a prime choice.
Touch Screen TFT LCD Display Module for Application
STONE is a seamless Human Machine Interface (HMI) solution that provides a control and visualization interface between a human and a process, machine, application or appliance. Stone is mainly applied to Internet of thing (IoT) or consumer electronics field. It is the best solution to replace the traditional LCD and LED Nixie tube.
We are using the high-quality component from the top-class supplier to build the display. And the superb manufacturing process makes the display can working in the harsh environment such as high/low temperature, high humidity or dust. The complicated environment in the workshop won’t affect the system and the operation.
Another major concern from the equipment owner is the accidently crash or stop for unknown reason. It will interrupt the working plan, and also will cost money and time to fix the issue. Stability of the equipment is very important for the automation customers.
STONE TFT display is using UART serial port and very simple hex command sets as the protocol. The communication between the controller and the display will be very easy and stable. The system can continuously work over 72 hours.
With the complete display and input function, you can achieve any application in your automation system. Our GUI design software can make the data display, data input, status display, column display and curve display, etc. All the function will be controlled by the variable value sending from the equipment controller.
Recommended model:  STVI serial
Like
