System Self-Test Registers Instruction (error code list)
94754sakura94754sakura wrote 05/31/2021 at 05:30 • 1 min read • Like
24 09 2020 337
The system self-test start method:
       Mode 1: Read the registers 0xf3-0xf6, the system will automatically start to verify all the files once.
       Mode 2: The system will check the files used in real-time when executing the program.
Structure output of the system self-check:
   When the file error message is verified, the error code is written to registers 0xf3-0xf6 and output in the following two ways.
       Way 1: Sending the error code in registers 0xf3-0xf6 by serial port via 0x81 instruction.
      For example, A5 5A 07 81 F3 04 00 51 00 0E
       Way 2: Display the error code in the upper left corner of the screen.
        You can use "miscelaneous.4" in "screen cue configuration" to set whether to display the error code or not. Details on 7-2-1 and 7-2-2.
        Checking "miscelaneous.4" enables the display of error code information on the screen.
        If you do not want the error code message to be displayed on the final product, you can uncheck the "miscellaneous.4 bit" option.
Appendix 2-1 System Self-Test Error Codes
(0xf3 0xf4)
Error code  (0xf5 0xf6)
Describe
0000
0x0001
SPI initialization exception
0000
0x0002
System parameters sysinitial exception
0000
0x0003
Read the Config exception
BIN_ID
0x0004
User data file exception
WAV_ID
0x0005
Wav file exception
Mp3_ID
0x0006
MP3 file exception
AVI_ID
0x0007
AVI file exception
FT0_ID
0x0008
The zero word exception
V22_ID
0X0009
Variable initialization file exception
UNICODE_ID
0x000a
The UNICODE word exception
FT_ASC_ID
0x000b
User ASCII font exception
FT_GB_ID
0x000c
User full-angle font exception
ICON_ID[7:0],
ICON_NUM[7:0]
ICON_ID[11:8],
ICON_NUM[11:8],
0x0d
Icon file exception
PIC_ID
0x000e
Image file exception
0000
0x0010
Engineering verification error, read F3 register to start and return engineering self-test results
0000
0x0011
The serial port receives an abnormal command
Like
