Instruction for list display (application DEMO for event log)
94754sakura94754sakura wrote 05/31/2021 at 05:31 • 3 min read • Like
18 09 2020 400 Nigel
We are using list display (form display) function to create an event log application
1. Software settings:
Instruction-for-list-display-application-DEMO-for-event-log
As the picture shows, we have split the log into 3 part: Date/time, AM/PM, Log
a. The variable memory address setting of each part will be separated
b. Each part is using a list with 1 column and 5 rows. You can define the row number regarding your situation
c. The unit data number is the data length in each unit. For Date/time, we need at least 6 bytes to display the whole data.
d. The direct variable display should be unchecked since we can define the Date/time display format
The rest part setting:
2. Command setting:
Please noticed that the list display function is only available on real display. The virtual serial screen function is not able to display it.
According to 5.3.3 in the development guide, the first 2 byte of the command should be:
12-display the date/time information
00-Undefined
07E0-text color (can be defined by yourself)
The rest part should be the BCD code of the date/time:
2020 0918 0205 3000 (2020/9/18, 02:05:30.00)
The full command sending to the serial port will be:
A5 5A 0F 82 00 00 12 00 07 E0 20 20 09 18 02 05 30 00 (6 bytes total)
For the other 2 parts, we just using variable directly display
Sending:
A5 5A 07 82 10 00 41 4D 50 4D (display AM in 1st row, PM in 2nd row)
A5 5A 1C 82 20 00 45 56 45 4E 54 20 4C 4F 47 20 54 45 53 54 20 53 54 4F 4E 45 20 54 45 43 48 (display EVENT LOG TEST STONE TECH in the log content)
The following links may help you
14 STONE TOOLBOX instruction tutorial
https://www.stoneitech.com/news/instructions
Like
